Post by skuttadawg on Nov 26, 2012 0:20:48 GMT -5
From all of the pictures I have seen it looks like those like me with a type 2 or rear facing carb can use a type one since they look the same on the bottom . I can see where a type 2 would not work on a type 1 since it has a long tube . I think the shorter type one will be more responsive since the carb is closer to the reed cage and have more vacuum .
I think some has said they did this and it worked out . I will break down and spend 30 bucks and find out and post the results
Post by fickertravis on Nov 30, 2012 18:07:49 GMT -5
It should work fine
Post by skuttadawg on Dec 1, 2012 22:32:18 GMT -5
Thanks I hope it will fit a 19mm TK carb . I got it running so good with 105 main jet
