Post by humanshield on Mar 6, 2015 19:42:14 GMT -5
I like fiberglass cloth and resin.
Post by runningbuck on Mar 22, 2015 20:33:25 GMT -5
I like the MEK method better worked great on other repairs I done in the past
Post by runningbuck on Mar 22, 2015 20:36:18 GMT -5
FYI (MEK = Methyl ethyl ketone (butanone), a solvent, used also to weld some plastics) paint department at hardware store or at paint stores
Post by baggedb22k on Apr 8, 2015 7:08:23 GMT -5
anybody tried using JBweld on cracks?
Post by Sitticuss on Apr 8, 2015 14:11:34 GMT -5
anybody tried using JBweld on cracks? Didn't work well for me. I have used Loctite epoxy plastic bonder with good results.
Post by albongo on Apr 8, 2015 16:30:44 GMT -5
I have had success with a gas powered soldiering iron and strips of and old panel to use as weld. I found it gives a better, stronger weld than using cable ties.
Post by scooterpimp on Apr 8, 2015 17:47:43 GMT -5
Used heavy guage staples with battery & gator clips to arc melt the staples into plastic then nip off ends to solid up crack , then use solder gun to melt the crack closed.. butt sometimes i like the franken stitch zip tie method for that mad max look!
Post by masteryoshi on Apr 28, 2015 20:37:59 GMT -5
Ive got some bondo fiberglass resin and fiberglass mesh left over from my car repair. That would adhere rigto the plastic right? Mines all held together with black ducktape right now lol
Post by scootordie on Jul 20, 2015 17:30:00 GMT -5
The best thing for repairing your cracked plastic came from my wife actually. Acrylic from doing acrylic nails works amazing. File or dremel out a groove in the crack, mix the acrylic liquid and powder (follow the directions or ask your wife) and fill the crack in. Sand it flush and paint. Its cheap and very strong!
