Post by martyd on Jan 2, 2013 1:02:24 GMT -5
My wife has a icebear ace/frontier depending where you buy it it is the 50cc model.
My question is does anyone know if you can raise the handlebars up
im not talking gorilla bars just 3-4 inches to make it more comfortable
for her. She loves the scooter except she wants the bars raised or
she is thinking of selling it if i can not figure out a way to do this
please help.
Post by PIG on Jan 2, 2013 11:23:24 GMT -5
You could switch to a motocross style bar and find the bend she likes. Also there's plenty of handlebar stems that come in all different lengths and colors.
Post by martyd on Jan 2, 2013 17:53:53 GMT -5
anyone else got any ideas?
Post by jmkjr72 on Jan 2, 2013 19:13:47 GMT -5
about the only other way would be to modify the riser for the bars remove it find some tube the exact same od and weld it on then you will proably have to add on to the wires and the throttle and brake cable i doubt there is enough slack for a 3 in change
Aaron420e
2008 Keeway F-ACT Racing
Post by Aaron420e on Jan 2, 2013 19:16:59 GMT -5
You could switch to a motocross style bar and find the bend she likes. Also there's plenty of handlebar stems that come in all different lengths and colors. I think that is your only option.... Stock bars are non adjustable... Unless you weld and do some fabrication and modification. A stem and bars aren't too much $$$. I'd hate to see a good scoot sold.
Post by martyd on Jan 2, 2013 21:04:52 GMT -5
ok but would a stem and bars actually raise it up any i have checked the cables and the wires theres about 2" of slack i can pull
Post by jmkjr72 on Jan 2, 2013 21:46:28 GMT -5
the stem will help some but you will have to find the bars that finish it up the way you want best bet is going to a shop that has some bars there and compare them to the oem bars
Post by martyd on Jan 2, 2013 21:52:45 GMT -5
thats one of the really crappy things about living where i do there is not a shop within a 100 miles from here i have to order anything i get
Post by teddy554 on Jan 3, 2013 0:27:56 GMT -5
my stem and bars are lower then stock also what way are the bars mounted to the stem that is a factor in what kind of stem to use
Post by martyd on Jan 3, 2013 0:33:40 GMT -5
the handlebars have shaft that slides over the shaft from the fork and a bolt goes through the middle
Post by scoottrash1990 on Jan 3, 2013 19:49:18 GMT -5
i really like the bar setup teddy....did you just remove your gauges or did you relocate them?
Post by teddy554 on Jan 3, 2013 19:59:23 GMT -5
just removed them, the plan was to get one of those s6 speedo tech all in one but been doing good with out it
Post by scoottrash1990 on Jan 3, 2013 20:48:14 GMT -5
ya i drive through a little town near me all the time and the speed limit is 25....the cops there are really board so they like to pull people over for little things like going 5 over the speed limit...i have to have my speedometer so i can stay out of trouble....
Post by PIG on Jan 3, 2013 23:03:48 GMT -5
I have that stage6 gauge its a pretty slick unit Attachments:
Post by scoottrash1990 on Jan 4, 2013 6:10:40 GMT -5
pig.... is it hard to wire and set up?
