Post by antirealm on Jan 8, 2013 19:54:56 GMT -5
I've come to notice now that when I first start the scoot she runs great. But then seems to get weaker as it gets warmer.
What could be the problem? I live in a hot climate in summer anyway, today was cold and it ran really well. Thanks
Post by jmkjr72 on Jan 8, 2013 20:11:32 GMT -5
as long as the plug is good and the air filter is clean
you can start with checking your enrichment circut (choke)
Post by antirealm on Jan 9, 2013 23:55:06 GMT -5
How do I check it exactly?
Post by 90GTVert on Jan 10, 2013 9:00:59 GMT -5
Easiest way is prob to pull out the enricher when cold and note the length. Then put it back in and let the scoot run for 5 minutes. Take it back out and check the length again. It should be longer when hot, as you can see in the video below. If not, you'll need to see if it's getting power. www.youtube.com/watch?v=O2qRVOkfdaY
