Post by bartlett39 on Jan 14, 2013 12:22:24 GMT -5
Hi, I have a 100cc 2 stroke bike that I have, and has suddenly developed this problem. It has air, spark and fuel and when running hardly idles and when throttle is applied it increases a tiny bit, not enough to move the bike, it just shakes a bit, I have no clue what it could be, I have tried a new clutch and that did nothing, it is like the bike has a restriction on the fuel but I have checked and the fuel is free flowing lovely, could this be a carb problem? ??
Post by 90GTVert on Jan 14, 2013 17:09:46 GMT -5
Post by jmkjr72 on Jan 14, 2013 18:09:12 GMT -5
any 2 stroke trouble shooting should start with new plug clean or replace the air filter and a carb cleaning
Post by bartlett39 on Jan 17, 2013 12:58:51 GMT -5
rite cleaned carb, new spark plug, new air filter still the same symptoms, the exhaust has oil coming out of it I forgot to mention. what do I do??
Post by 90GTVert on Jan 17, 2013 13:20:18 GMT -5
Was the plug oily? If so, maybe you've got excess oil getting in from a failed check valve. If the plug isn't oily, perhaps the exhaust is getting plugged?
Post by jmkjr72 on Jan 17, 2013 19:09:17 GMT -5
clean the exhaust out
i like to hang them plug one end and fill them with solvent and let them sit for a while and then drain the solvent pour more solvent thru to make sure it flows thur easily
then you will need to let the pipe sit long enough to let the solvan evoprate
Blowin Smoke
Post by Blowin Smoke on Jan 18, 2013 10:39:02 GMT -5
I do the same thing but I use liquid plumber. Shake it every once in a while. Rinse with clean water when finished. You can drain it into a sink or .............................
Post by jmkjr72 on Jan 18, 2013 16:41:09 GMT -5
you cant drain it into a sink it has oil and other wastes in the pipe that will not be treated properly at the waste water treatement plant
