Post by 808twosmoker on Jan 16, 2013 16:47:31 GMT -5
I have a Chinese Jog clone: BBK, expansion chamber pipe, OKO 28mm Flat slide carb, coil, new plug, upgraded reeds plus all the CVT you can do.
Problem: bike will not start unless im on the throttle, it does run like a scalded dog WOT. dies when coming to stop and has a REALLY hard time starting.
I have taken the entire engine apart, fuel lines, vacuum lines, carb and made sure everything is sealing good, no cracks in any lines. after i put it all back together it will start and idle but as soon as i ride it back to the same old sh** WONT IDLE and its SUUUPPPPPPPERR boggy on the bottom end.
i have tried changing both pilot and main jets going up and down in size and playing with the air screw. nothing seems to help.
currently I have: 38,48 and 50 pilot jets and 122,128 and 130 main jets.
i'mat sea level and the temp never changes more than 70-85 degrees in Hawaii sooo....
WTH?!
ANYONE?
Post by 90GTVert on Jan 16, 2013 16:55:15 GMT -5
For one thing, the big carb amplifies your tuning headaches.
Sounds like you need to work with the pilot/air screw more, and probably the needle or needle setting as well. Since you say it runs well WOT, perhaps start by making sure that's dialed in the best you can get it. You may need more jets to get it just right. Then work with the other settings.
Post by 808twosmoker on Jan 16, 2013 17:01:49 GMT -5
I'm pretty sure its all in the pilot jet but it sure is pissing me off! also, weird thing... when i first installed it about 3 weeks ago i put in the 48p and the 128m and it ran fine... idled, ran great WOT and didnt die... now, BS
Post by 808twosmoker on Jan 16, 2013 17:02:41 GMT -5
Im not really sure what you mean by "needle setting" enlighten me obi one
Post by 90GTVert on Jan 16, 2013 17:17:29 GMT -5
The needle should have a clip on it and multiple grooves. If you move the clip up it will lower the needle and lean out the part throttle mixture more. If you move the clip down it will raise the needle and richen the part throttle mixture.
Post by 808twosmoker on Jan 16, 2013 17:23:09 GMT -5
ahhhhh ok. which way you think i should go first?
Post by kevin55950 on Jan 16, 2013 17:25:40 GMT -5
Make the needle clip higher to the top. 4th or 5th clip will get you leaner. Your needle will go deeper in the carburetor fuel bowl.
Post by 808twosmoker on Jan 16, 2013 17:41:24 GMT -5
done! started up pretty much right away. gonna test drive it in a bit! Mahalo for the tips!!!!
Post by 808twosmoker on Feb 4, 2013 22:41:54 GMT -5
So now I'm having another issue, got it running after adjusting the needle farther down but the damn needle won't stay seated!! It keeps coming up this causing the bike to bog out
Post by 2strokd on Feb 8, 2013 10:13:19 GMT -5
You are missing something then. There is supposed to be a little metal, or plastic clip that holds the needle seated in the slide. Without this it will move freely. Good thing you had the c-clip on or it could have ended up in the engine?
