new parts:
1 cockpit koso
1 navi garmin zumo 550
1 kit malossi
1 kit pm tuning pro street 2
1 kit pm tuning pro street 1
1 kit ngf
2 crankshaft malossi mod for 55 mm stroke 110 rod
1 crankshaft bgm mod for 56 mm stroke 110 rod
8 crank bearing skf
8 polini crankshaft sealing
2 water pump
1 vario polini
1 malossi delta
1 clutuh bell polini
2 clutch bell pm tuning
1 complete rear pulley assemble
1 cover final trans
1 set of oem 180 gears
1 set bearing and sealing for final trans
8 subframe teflon bush
1 silent 45 shra
2 silent engine
1 silent rear shock
2 tire raceman schwalbe
2 bearing front wheel
1 front wheel axle
1 fork malossi f 32s
1 fork vespa gt 300
1 brake disc 250 newfren spacer and brake pads
1 brake disk 250 purte1
1 spacer for radial caliper stage 6 on fork vx-vxr
1 spacer for radial caliper stage 6 on malossi f32s
2 radial caliper stage6
1 rear brake pad set
2 red aero brake line(spiegler)
1 red sponge malossi runner 180
2 airbox runner 180
1 red sponge malossi runner 50
1 airbox doppler runner 50
1 reeds valve polini evo
1 reeds valve vforce tassinari
1 reeds valve v force stage 6 +carbon fiber reeds
1 reeds boyesen double system
1 reeds valve old big polini
1 reeds valve vl 16
15 gaskset reeds valve
6 mm delli jet from 72 to 122
1 Variator rollers polini 14 gr
1 Variator rollers polini 14.6 gr
1 Variator rollers polini 15 gr
12 set malossi 20x17 rolls
1 malossi phvb 22
1 malossi phbl 25
1 exhaust oem no kat
1 exhaust scorpion
1 sip header 34 mm stainless
1 cable and spark plug connector ngk
3 tacho cable....
1 series clutch spings malossi
1 intake mainfold oem
1 straight intake mainfold malossi
1 360 intake mainfold malossi
all lamps
2 rear mirrors
1 battery yuasa
1 air filter tube airbox-frame
1 air filter tube lamby (for use with straight mainfold)
10 fairing screws
10 spring plate fairing
5 spring plate m6
5 screw m6 fairing
1 oem contrast sping
1 oem vario v belt
1 hand grip right
1 hand grip left
1 pump belt
5 screw (m6x60)
5 screw (m6x35)
1 rear center cover
1 front center cover
1 front turn signal vxr right
1 front turn signal vxr left
1 rear handlebar cover
1 temp sensor
1 rubber gaskset belt carter cover
1 inf foot rest right
1 inf foot rest left
1 fuel filler flap
1 complete vxr rear light
10 fairings screw
1 rear plate holder /mudguard
1 front shock rs 24
1 rear shock de carbon
1 rear shock bitubo
2 rear shock rs 24
2 series head steering bearing
1 series Dust protection + oil seal vx-vxr fork
1 front air intake right
1 front air intake left
1 rubber under fuel cap
1 rubber under oil cap
1 switch light
trans oil , liquid cooling , brake fluid
20 liter oli motul 710
all tools i need (buzzetti)
used stuff:
1 cockpit koso with 4468 km
1 seat purejet2004
1 sebac fork gold cap
1 v belt trans cover
1 airbox runner 180
1 rear right fairing runner 125 sp black
1 front left fairing runner 180 black
1 front wheel
1 rear wheel
1 rear wheel vxr
1 fron mudguard vespa lx
1 mudguard runner 50
1 crankcase with trans from 180 disc
1 cranckase with trans 180 rolling nut
1 cranckase with trans 125 rolling nut
1 cranckase complete tph 125 rolling nut
1 stage6 mina am6 intake mainfold
and other 3 complete engine
if i remeber all well
