Post by elsjog on Feb 26, 2013 8:59:32 GMT -5
I Have a Yamaha Jog 2Ja (vertical engine) and the previous owner took out the rectifier/regulator along with the wires going to it. I bought a new one but dont know which terminals goes to the stator, battery and ground. Does anyone know where the upper right, upper left, lower right and lower left pins/terminals of the rectifier connect to?
Post by 90GTVert on Feb 26, 2013 10:39:19 GMT -5
Post by elsjog on Mar 21, 2013 23:38:52 GMT -5
Just found a wiring diagram for the rectifier for my scoot. As i was about to put the rectifier in, there was a really small device connected to the red wire(+ battery) and white(stator). I believe its a doide but not sure. It has a symbol of ->||<- . Is this stock to the jog?
Post by aznatama on Mar 22, 2013 2:22:56 GMT -5
can you test it with a multimeter? is it a fuse?
Post by elsjog on Mar 22, 2013 2:48:29 GMT -5
Its not a fuse. Its a small 1cm cube like plastic coated, with two prongs with a symbol of two arrows facing each other with two vertical lines in between. I dont think its original to the scoot because it was soldered directly to the wires unlike original components which has removable terminal clips. When i got the scoot the rectifier was missing. The symbol on the thing are similar to a varactor diode.
Post by elsjog on Mar 22, 2013 2:50:20 GMT -5
Btw, im not an expert on using a multimeter tester so any advice on how to use it would be nice.
