havoc
Post by havoc on Mar 7, 2013 15:24:25 GMT -5
www.youtube.com/watch?v=gcZVgg4jAHQ&feature=youtube_gdata_player that is full throttle... now it refuses to start f*****g thing change spark plug compression is fine fuel reaching carb erm... havent checked reeds do have my old set with me any idears it worked fine after i shot that video untill 30miles from home then just cut out and wont start...bare in mind im working by bloody flash light here as im in the middle of no where with no phone signal...might have to build me a shelter as looks as im camping under the stars lol... im damn hoping this is my last thread about this bike once its up and running
Post by 90GTVert on Mar 7, 2013 16:08:05 GMT -5
It seems to be rich, possibly misfiring due to ignition issues.
You should know if the float were stuck, cause you'd have a puddle of fuel under the scoot by now.
If it were the main jet size, it shouldn't run well at 3/4 to WOT ever. I suppose it's possible a loose main jet could come out, but wouldn't be the first place I'd look.
Could be a reed sealing issue, or broken reed.
Could be an air filter issue or some sort of obstruction there.
I'd pull the plug out so if it's managed to flood itself you will know from the wet plug and you can let it air out so hopefully the excess gas can evaporate more quickly. While it's out you could check the gap, but most don't carry a gapper with them to do so. If the gap were too wide it could misfire.
Check for spark, hopefully consistent.
Check connections anywhere you can reach for the ignition system and grounds... CDI, coil, stator, plug wire, plug cap, engine and frame grounds.
I know that's a lot of stuff to look at, but I'm sure you'd like to check as much as possible and get on your way.
Post by teddy554 on Mar 7, 2013 16:41:33 GMT -5
water in the fuel can cause that also, dealt with that on both my scoots
Blowin Smoke
Post by Blowin Smoke on Mar 7, 2013 19:39:51 GMT -5
It may start after the engine cools. I had that problem with one of mine.
Blowin Smoke
Post by Blowin Smoke on Mar 7, 2013 19:42:59 GMT -5
That sounds like a bad plug to me
Post by Fox on Mar 7, 2013 23:44:56 GMT -5
Sometimes when a CDI goes bad it will spark but not at the right time.
havoc
Post by havoc on Mar 8, 2013 8:50:46 GMT -5
FIXED bad coil got that replaced along with another spanking new spark plug now it fires up first time every time
Blowin Smoke
Post by Blowin Smoke on Mar 9, 2013 13:14:51 GMT -5
What plug are you useing?
havoc
Post by havoc on Mar 11, 2013 6:54:52 GMT -5
later reply....its a br8es i think but will check
