liftit
Post by liftit on Mar 9, 2013 18:25:06 GMT -5
I have a Zip clone with the low profile tire on front. I really don't want the low profile. Can I just swap a taller tire on the same rim, or is it some sort of special rim? I'd rather not have to go through the hassle of trying to find a rim that fits.
Post by shakerdriver on Mar 9, 2013 18:46:47 GMT -5
You can use the same rim but the speedo will be off. Its calculated for the tire diameter and by putting a bigger tire on it your changing that number. If you can find a speedo puck that is calculated for the bigger tire you can make it somewhat close again.
