Post by jaytheking13 on Mar 14, 2013 0:52:47 GMT -5
So today my scooter was warming up on the kick stand, and my dad thought it was a good idea to rev the hell out of it. Causing the clutch to engage and accelerate the bike off the kick stand and it falling over.
End result was damaged body and fuel leaking out of carb, other than that is there anything else that could have been damaged? im still new to scooters and im really not sure what i should be looking for?
Post by 90GTVert on Mar 14, 2013 8:49:12 GMT -5
Sorry to hear it. You've prob seen the extent of the damage as long as you aren't noticing any other symptoms. Is the fuel still leaking, or it stopped shortly after picking it up?
Post by jaytheking13 on Mar 14, 2013 19:34:13 GMT -5
Yeah the fuel stopped leaking, some coolant leaked for a bit. The only thing I'm noticing is a little more noise from the transmission.
Post by aznatama on Mar 14, 2013 20:55:56 GMT -5
fuel was most likely just the overflow, which is normal. Coolant, possibly the same thing. Noise from tranny... I don't know. Take it into a shop to get it checked out since your dad tipped it over, it's his responsibility to fix it.
Post by Fox on Mar 14, 2013 21:09:07 GMT -5
The tranny noise could just be the kicker gears not seated properly (if it has kicker) Work it a few times with the engine off and then start it to see if it goes away.
I crashed my scoot a while back and the damn fuel gauge has been spotty ever since. It's always something with these.
