Post by teddy554 on Mar 16, 2013 19:08:33 GMT -5
Had time to day to tune my new 90cc motor and got it running real good and notice i had no lights or any electrical power any where but fires up and runs fine. im not sure if the stator on the 90cc motr or the electrical system on my scooter causing this before i put the 90cc motor in my 70cc motor did the same thing started blowing lights then i change the rectifier didnt help then i lose all electrical then the stator finale went. Could this just be a bad stator or can something in the scooter wiring be causing my stator to go bad
Post by 90GTVert on Mar 16, 2013 19:35:44 GMT -5
Post by teddy554 on Mar 16, 2013 19:45:40 GMT -5
The rectifier is new, no but i will I am thinking of taking all the plastic off and checking everything and cleaning.Going to check the rectifier again like the link says to do so i would swap out the two top plugs from the harness or has the bottom picture says.
Post by teddy554 on Mar 22, 2013 17:35:44 GMT -5
Put the new stator on and my old rectifier(like the one in the link) on and everything is back to normal
Post by 90GTVert on Mar 22, 2013 18:05:30 GMT -5
Glad it's working.
Post by teddy554 on Mar 22, 2013 18:16:51 GMT -5
Thanks the stator i took off look newer then i put on is there anyway to fix it
