Post by jaytheking13 on Mar 29, 2013 21:40:59 GMT -5
You should be able to find gear oil for the case. As for the brakes, sounds like you may have an issue if it's hot. press the pistons in, and see if they stay in. Have you done any brake work recently? Have you bled the brakes just to flush out the system? hydraulic brakes dragging sounds like a weird problem, sound like something is not releasing pressure (master cyl?) or the pistons are gummed up and need to be rebuilt. Since ive had the scooter i have done 1500km on it and the only work ive done to it is replace an exaust gasket and new temp sensor. As for the break, i think thats what might be the problem, took it over to my mechanic today and he says its probably the master cyl just by pulling the leaver. Is there any way i can fix that as i dont have money to pay to get it fixed and if i can do it myself i would do it. Edit: I risked not knowing what im doing but i took of the rear break and when i pull the leaver only one cylinder moves, is that right?
Post by ryan on Mar 29, 2013 22:03:25 GMT -5
put in 85w-90 gear oil when refill it...there are some videos on youtube of how to rebuild motorcycle calipers
Post by jaytheking13 on Apr 3, 2013 1:16:26 GMT -5
drain your gear oil and measure it..maybe your gears are locking up from to low of oil level. Your answer was right on the money. Drained the gear oil and only something like 25ml came out and was all grey looking and smelt badly burnt. dragging problem gone away. As for the rear breaks, i bled the whole system and washed the pads and disk and it seems a lot better. Now i have a new problem LOL
Post by ryan on Apr 3, 2013 9:33:18 GMT -5
told you...lol i bet your gear box was making a squeak sound also..thats what gears do before they lock. and the box gets hot
theo547
Post by theo547 on Apr 6, 2013 10:44:28 GMT -5
happy to hear your problem is solved... only because its bothering me - "Brakes" not "Breaks"- as in - brake pads - not - sometimes the window breaks
