Post by muffinnutz on Apr 10, 2013 7:26:25 GMT -5
I have just put a 2006 engine into a 2011 tao tao the only drastic problem I have is there is one extra wire on the magneto plug on the 2011.Ok I started to try to see if I could come up with a wire configuration to get it to work . Didn't go so well so to elaborate a little more the first picture is of the 2006 wires that come out of the magneto and at first I thought because I had two male ends I could just cut and splice in a female. That didn't work, so I started trying different combo's as the 2011 engine and bike have an extra butt connector. So the 2nd picture is of the bike just realized it's a little hard to see but one of the butt connectors is kinda touching the muffler. the last is the pic of the 2011 engine that I removed however you can see I have one extra wire. Can I just swap the magneto's or is there a wire combo that will work or another solution? If I pull the magneto's can I use just a standard gear puller or is there a special tool for that? I am more accustomed to working on american stuff or Honda's. They look like they should just swap over I'm just trying to be cautious as all the other easy stuff hasn't been that easy and trying to avoid butchering the whole thing up. Thanks.
Read more: 49ccscoot.proboards.com/thread/5764/swap-magneto-2011-2006-49cc#ixzz2Q3uRfdlj
Post by Deleted on Apr 10, 2013 9:01:10 GMT -5
does this bike have a tachometer on it?
Post by ryan on Apr 10, 2013 12:20:29 GMT -5
are you sure its a AC or DC engine..if both gy6 switch out stators easiest fix
Post by muffinnutz on Apr 10, 2013 15:03:02 GMT -5
Neuther have a tach
Post by Deleted on Apr 10, 2013 17:52:02 GMT -5
Post by Deleted on Apr 10, 2013 17:53:56 GMT -5
are you sure its a AC or DC engine..if both gy6 switch out stators easiest fix Its AC to the R/R and the R/R changes it to 12v. ALL 139qmb stators are Alternating current.
Post by Deleted on Apr 10, 2013 18:05:55 GMT -5
Post by ryan on Apr 10, 2013 19:58:06 GMT -5
i have a taotao vip thats dc engine..but im not here to argue
