Post by ʇwiƨtɘdburnout on Apr 17, 2013 14:07:24 GMT -5
I just found a cool, simple, cheap and easy trick and wanted to share it. Just take an old toothbrush and use tooth paste on the lens, rinse it all off good..... and BAM! Attachments:
Post by Fox on Apr 17, 2013 14:38:43 GMT -5
I use this stuff called Gel-Gloss. It's for polishing fiberglass boats, marble countertops etc.. It's basically a polish/wax. Any decent car polish/wax should work.
The Gel-Gloss makes foggy speedo lenses clear again.
Post by 90GTVert on Apr 17, 2013 15:53:38 GMT -5
I've used metal polish with pretty good results. Worst thing is, it's not always on the outside of the lens. My mother's '01 GT (headlights like the pic) had bad discoloration and half of it was inside the lens.
Post by aznatama on Apr 17, 2013 17:42:55 GMT -5
I've used Plexus with good results. It was developed for the aircraft industry, and I've used it extensively when detailing show cars for auto shows and conventions. Toothpaste works since it acts as a mild abrasive, which is how it polished your enamel as well. For deeper stains and pits, you'll need a stronger abrasive though. Perhaps even fine-grit automotive sandpaper if it's really bad.
Post by scoottrash1990 on Apr 18, 2013 18:59:04 GMT -5
i use mothers aluminum wheel polish....worked really good for me...then i wax them to keep them from fogging up again....
Post by Fox on Apr 19, 2013 15:54:39 GMT -5
So the consensus is that a fine abrasive polish/wax is the ticket!
Post by scoottrash1990 on Apr 19, 2013 21:06:57 GMT -5
right.....lol
Post by Suprtigr on Jul 29, 2013 22:04:34 GMT -5
Just had to put my input. Auto tech teacher showed me that using wet 1000grit sand paper in a horizontal fashion then moving up progressively to 3000grit then buffing works well. Did it on my mother's headlights and it worked like a charm.
Post by toslowtogo on Aug 9, 2013 15:34:53 GMT -5
Post by zombies2slay on Aug 10, 2013 9:30:32 GMT -5
I concur with Suprtigr and the tech teacher. I painted cars for a while and this the technique we used. Wet sand and buff. We used a buffing sponge attached to a drill. Like the ones you can buy for cleaning rims. Mother's polish sells a nice one. They shine like fresh chrome if done right. Just remember to follow the same pattern no ziggy zaggy or circles.
