Minarelli/Jog Clone Info : Bearings , Seals, Torque, & More
May 25, 2013 12:28:08 GMT -5
2strokd, kevin55950, and 2 more like this
Post by 90GTVert on May 25, 2013 12:28:08 GMT -5
This thread is full of all sorts of specifications for the most common short and long case Chinese Minarelli clone engines (1E40QMB). There are some strange variations in Chinese scooters, so it's always best to check your scooter before working on it or ordering parts for it. Use the info here at your own risk.
Bearings
Crankshaft(x2)
Number | I.D. | O.D. | Thickness |
6204 C3 | 20mm | 47mm | 14mm |
Wrist Pin
Wrist pins come in two common variations on Chinese clone Minarellis, 10mm and 12mm. The bearings of course are not interchangeable, so you need to know which you have before selecting a wrist pin bearing. More info HERE.
The length of the wrist pin bearing may depend on the displacement/bore of the engine. Smaller pistons cannot fit the longest pins. O.D. with the pin out may vary depending on the design of the needle bearing.
Number | I.D. | O.D. | Length |
10mm Wrist Pin 50cc | 10mm | 13-14mm | 12.5-14mm |
10mm Wrist Pin 70cc+ | 10mm | 13-14mm | 14-16mm |
12mm Wrist Pin 50cc | 12mm | 15-16mm | 12.5-14mm |
12mm Wrist Pin 70cc+ | 12mm | 15-16mm | 14-16mm |
Wiseco B1043 | 12mm | 16mm | 15mm |
Engine Mount (x2)
(Not all Minarelli/Jog clones use this style of engine mount.)
6003-2RS | 17mm | 35mm | 10mm |
CVT Cover (Primary Drive Shaft Support)
638Z 638ZZ | 8mm | 28mm | 9mm |
Primary Drive Shaft (Short Case)
6003 | 17mm | 35mm | 10mm |
Primary Drive Shaft (Long Case)
6203 | 17mm | 40mm | 12mm |
Counter Shaft (Short Case)
6201 | 12mm | 32mm | 10mm |
Counter Shaft (Long Case)
6200 | 10mm | 30mm | 9mm |
Secondary Shaft (Short Case)
HMK 2515 | 25mm | 33mm | 15mm |
Secondary Shaft (Long Case)
6202 | 15mm | 35mm | 11mm |
Rear Axle (Short Case)
6004LU | 20mm | 42mm | 12mm |
Rear Axle (Long Case)
6004-2RS | 20mm | 42mm | 12mm |
Seals
Crankshaft(Left/CVT Side)
20mm | 42mm | 8mm |
Crankshaft(Right/Stator Side)
20mm | 30mm | 6mm |
Primary Drive Shaft(Short Case)
17mm | 28mm | 5.5mm |
Primary Drive Shaft(Long Case)
17mm | 35mm | 7mm |
Secondary Shaft(Long Case)
25mm | 44mm | 7mm |
Bushings
Rear Shock Mount
8mm | 20mm | 20mm |
