Post by fugaziiv on May 15, 2018 13:24:17 GMT -5
Just going to throw my $.02 in. I've placed small orders with them on several occasions, never been given any reason not to order from them again. Packages usually arrive a few days after I order them. I'll continue calling on them until they give me a reason not to. If we keep doing our job right, the day you have a reason not to call us should never come. Thanks for the kind words everybody! Matt
Post by 90GTVert on May 16, 2018 22:25:12 GMT -5
Ordered a CVT cover not long ago. Came damaged. Plastic cover broken, paint missing. Looked like it was that way when sent since the box was not damaged and there was no plastic in the box. Emailed them. They told me to keep the cover and issued a refund for the part. I did have to pay shipping still. Fair enough though, because the cover is usable. I didn't ask for an exchange BTW because it's a deeper cover than some and I'm not sure if it provides the same support for a primary drive shaft bearing. Don't really know.
Post by eclark5483 on May 17, 2018 3:42:55 GMT -5
Post by fugaziiv on May 17, 2018 8:33:51 GMT -5
These two stands are not interchangeable. The mounting points have different measurements. However, just to make sure which stand you have it would be a good idea of measure the mounting points and height of the stand itself. The stand may look like one, but actually fit like the other... because China. Matt
Post by fugaziiv on May 17, 2018 8:38:21 GMT -5
Ordered a CVT cover not long ago. Came damaged. Plastic cover broken, paint missing. Looked like it was that way when sent since the box was not damaged and there was no plastic in the box. Emailed them. They told me to keep the cover and issued a refund for the part. I did have to pay shipping still. Fair enough though, because the cover is usable. I didn't ask for an exchange BTW because it's a deeper cover than some and I'm not sure if it provides the same support for a primary drive shaft bearing. Don't really know. Brent, Actually you should have been refunded shipping as well as it's not your fault in any way that the item you received was subpar. I'll have that taken care of. Additionally, I did go through stock and it looks like there were 2 or 3 in similar condition to yours. I took them out of stock and personally verified that the rest were as pictured. Honestly, the one you got never should have slipped by our QC. Embarrassing. Matt
Post by 90GTVert on May 17, 2018 12:55:07 GMT -5
Brent, Actually you should have been refunded shipping as well as it's not your fault in any way that the item you received was subpar. I'll have that taken care of. Additionally, I did go through stock and it looks like there were 2 or 3 in similar condition to yours. I took them out of stock and personally verified that the rest were as pictured. Honestly, the one you got never should have slipped by our QC. Embarrassing. Matt The cover is usable as it's cosmetic and then the plastic cover part. I feel it's fair as-is. I know you guys can't sell it, but I did end up with a cover that I'll prob use someday for just over $11 in shipping. Re : embarassing... everyone has an off day. I've ordered a lot of stuff over the years and I have had very few issues.
artman4life
Post by artman4life on May 29, 2018 20:52:00 GMT -5
Ordered new rear wheel, horn button, carb needle, main jet, and variator spacer last thursday before holiday weekend. Arrived a day early from shipping tracking eta. Horn button is wrong but thats my fault for thinkg my horn button was plug n play. Not the case when i went to change it. New wheel is painted and ready to swap tomorrow after work. Everything was packaged nicely. First order i made with them and will again in future 👍
harleyracer59
Scoot Veteran
I'd rather be lucky than good. Good takes practice lucky just happens
Post by harleyracer59 on Aug 13, 2018 21:30:49 GMT -5
hey fugaziiv
just noticed the af05 bbk pictures on the sight gotta be wrong. the gakets and the cylinder aren't correct. exhaust port should be angled to the side.
also can you get special bearings? say a narrowed 6204. Im looking for 20x 47x 12mm C3 if possible. thanks
Post by fugaziiv on Aug 14, 2018 8:45:11 GMT -5
hey fugaziiv just noticed the af05 bbk pictures on the sight gotta be wrong. the gakets and the cylinder aren't correct. exhaust port should be angled to the side. also can you get special bearings? say a narrowed 6204. Im looking for 20x 47x 12mm C3 if possible. thanks Lemme go check... And... yep, you're absolutely correct. The Polini kit is for Euro Honda LEAD/vision which has a different exhaust angle. This kit looks to be correct however, right? www.partsforscooters.com/158-2-Airsal-Cylinder-Kit-HondaAs far as the bearing, I don't have that size at the moment, and while I can get them it will take me a bit to get them in (probably longer than you want to wait). Additionally, a special order will probably cost more than if you just go to this link: www.123bearing.com/bearing-6204-W12-C3.php?gclid=CjwKCAjw-8nbBRBnEiwAqWt1zcO8QgTBOCfgZw91UR9Q2krq1sf8VnenlD95OkuKzumYOMA7wcOUGBoCsyIQAvD_BwEHope this helps, and thanks for pointing out our error. I'll get it corrected pronto. Matt
PirateLabs
Post by PirateLabs on Aug 14, 2018 9:07:33 GMT -5
I have only placed one order from them and it was for a small, inexpensive part but, my part arrived in just 2 days and fit perfectly and all is well. Could not ask for anything more.
Bill
harleyracer59
Scoot Veteran
Post by harleyracer59 on Aug 14, 2018 12:09:47 GMT -5
nope. the AF05 cylinder ports and flange should look like the 2 on the right (1 is aluminum). also if its for the lead/ vision then the ports should look like those on cylinder 2 from the left. they ran an AB07 till 83 and got the AF05 in 84 (a year earlier than the US). I'd be interested in a Lead/ vision cylinder if that's what theyre for. ab07 bbk are extinct or so I thought...  also the bearing is for an af05. only # I can find other than the honda # is E20. and that's some weird 2 piece bearing for a sachs moped.
Post by fugaziiv on Aug 14, 2018 12:25:28 GMT -5
nope. the AF05 cylinder ports and flange should look like the 2 on the right (1 is aluminum). also if its for the lead/ vision then the ports should look like those on cylinder 2 from the left. they ran an AB07 till 83 and got the AF05 in 84 (a year earlier than the US). I'd be interested in a Lead/ vision cylinder if that's what theyre for. ab07 bbk are extinct or so I thought...  also the bearing is for an af05. only # I can find other than the honda # is E20. and that's some weird 2 piece bearing for a sachs moped.   Let me grab some stock and I'll shoot some pictures so you can see what we see. I don't think the images on our site are doing the parts any favors... Matt
harleyracer59
Scoot Veteran
Post by harleyracer59 on Aug 14, 2018 12:30:47 GMT -5
awesome! im interested to see. thanks for the fast responses, like always! lol
btw, does your forum name/ handle have anything to do with the punk band? head of them? thanks Nick
Post by fugaziiv on Aug 14, 2018 12:36:14 GMT -5
awesome! im interested to see. thanks for the fast responses, like always! lol btw, does your forum name/ handle have anything to do with the punk band? head of them? thanks Nick Hah, it does! I'm and old punk guy and I've been using this handle (or some variation of it anyway) for like a million years. Matt
Post by fugaziiv on Aug 14, 2018 14:37:57 GMT -5
nope. the AF05 cylinder ports and flange should look like the 2 on the right (1 is aluminum). also if its for the lead/ vision then the ports should look like those on cylinder 2 from the left. they ran an AB07 till 83 and got the AF05 in 84 (a year earlier than the US). I'd be interested in a Lead/ vision cylinder if that's what theyre for. ab07 bbk are extinct or so I thought...  also the bearing is for an af05. only # I can find other than the honda # is E20. and that's some weird 2 piece bearing for a sachs moped.   Okay, Finally had a moment. So, on the left is what we believe to be an Airsal AF05 Cylinder, PN: 158-2, and on the right a Polini Lead/Vision Cylinder, PN: 146-49.   Matt
