Post by forde88 on Jun 23, 2013 23:02:12 GMT -5
Hi, Dont know if anyone will be interested but this is my 2001 speedfight 100 i got it to fix up for a runaround. Bought it in summer 2010, did a bit of work to it but it has been lying in the garage untouched pretty much since november 2010 as i have been busy moving house, working etc. Have started it up once since then lol. Actually a good wee bike pretty much no rust as a racer just used it for a paddock bike for most of its life, so its only got 6000km and the engine goes real well. At least it did last time i started it. Anyway i just bought a parts bike for £30 last weekend and split it all down into parts so hope to get started again. Back when i first got it i did all this - Replaced with brand new parts - mirrors levers speedo cable rear tyre battery front and rear shocks front pads. These parts have been replaced with secondhand ones - clock cover panel front caliper speedo drive knee panel front inner splashguard headlight panel headlights front side panel rear mudguard couple of indicators VHT exhaust and refit with new studs and gasket centre stand Still to do: Fit new master cylinder as mine leaks Bleed Brakes Strip and clean carb Strip and clean calipers Change plug, airfilter and rollers Fix kickstart Test oil pump Refit panels, exhaust, airbox and all other parts that are off it Respray this is what a speedfight looks like when assembled in case you USA folk dont know
Post by moofus02 on Jun 24, 2013 0:30:16 GMT -5
Cool looking bike. Thanks for the pics
