Post by sjfishon on Oct 22, 2015 10:21:00 GMT -5
fox,,, i like the way you think;;; 2by 4 and pipe, what else does you need;;;;;
Post by Senna1Rossi on May 6, 2016 16:49:09 GMT -5
Rubber hammer to break the beads. Gasoline to get it back on. I'm Canadian.
Whoa, does the gas in the tire actually work? how do you do that?
Post by 2stroked on May 6, 2016 18:24:51 GMT -5
It will work, but it's hella dangerous.....
Same with ether...
Spray a little inside the tire after its on the rim, light a match stand back and drop the match in and watch out...POOF!!!
Might not be the best way, but sometimes we ain't to smart in the hills....lol.lol.lol
If ya gonna be crazy and do this,,, anchor the wheel to the ground first..I have seen tires and steel rims launched way in the air with this method. Fun to watch.....from a distance. Nail biting to do at times...
I stopped doing that a long time ago, unless it's those big ass flotation tires like the OLD Intl log truck use up front. Sometimes ether won't even seal those big ownery sons a B.........
Post by oldgeek on May 6, 2016 21:28:38 GMT -5
I used my 20 ton shop press an a couple 2x4's the last time I changed a tire.
Post by gsx600racer on May 7, 2016 1:04:00 GMT -5
I bought the $50 tire changer from Harbor Freight. Has a bead breaker on it. Iv mounted to a 2x8x36 piece of oak so I can keep it out of the way when it not being used. A good set of tire spoons and some rim protectors completes the package.
Post by aeroxbud on May 8, 2016 19:54:30 GMT -5
I bought the $50 tire changer from Harbor Freight. Has a bead breaker on it. Iv mounted to a 2x8x36 piece of oak so I can keep it out of the way when it not being used. A good set of tire spoons and some rim protectors completes the package. I have just brought this one. www.vidaxl.co.uk/p/210225/professional-motorcycle-tire-changer-red Was so cheap got to be worth a go
Post by gsx600racer on May 12, 2016 23:15:49 GMT -5
I bought the $50 tire changer from Harbor Freight. Has a bead breaker on it. Iv mounted to a 2x8x36 piece of oak so I can keep it out of the way when it not being used. A good set of tire spoons and some rim protectors completes the package. I actually had to change a tire today, here is a pic of my setup.
Post by FrankenMech on May 22, 2016 17:07:17 GMT -5
Back in the day one of the guys in the service station could seat tires by hand. He could seat both beads at once on a 15" tire just by slamming the tire down on the rim. He just used his hands to break the beads also. We had a power tire machine but it was easier for him to do it by hand.
He was a BIG 'ol boy.
Post by renagade281 on Jun 5, 2016 0:54:31 GMT -5
I break the bead with a vice and then 2 or 3 good prybars about a foot and a half long to remove and put the new tire on. I got pretty good at it the last couple days. Had to do it like 4 times
Post by aeroxbud on Jun 5, 2016 19:03:58 GMT -5
I break the bead with a vice and then 2 or 3 good prybars about a foot and a half long to remove and put the new tire on. I got pretty good at it the last couple days. Had to do it like 4 times It is defiantly one of those skills that improve with practice
