Post by dagostinoa1 on May 19, 2010 17:30:00 GMT -5
So, i was having trouble with the scooter before and I thought I solved the problem. I couldnt find the correct fuel pump so i ran the gas lines right to the carb and pre mixed the fuel. The scooter ran fine for two days and now it starts, but will not accelerate. The scooter feels like its bogging down and will only go 5 mph. I took the plug out and it was pretty gummed up. My question is, where does the oil get injected, into the carb or directly into the engine. We left some oil in the oil tank so im wondering if that is still getting injected into the motor on top of the pre mix. So where does the oil get injected, directly into the motor, or into the carb? SOMEONE PLEASE HELP!!!!!
Post by 90GTVert on May 19, 2010 17:44:56 GMT -5
Post by redorchestra on May 23, 2010 8:11:55 GMT -5
my oil is fed into a tiny carb looking thing next to the real carb. Follow your throttle cable it might split and one goes to the carb and one goes to the oil injection.
