Post by craisin on Jun 26, 2014 10:21:15 GMT -5
This is radical read the comments
Post by craisin on Jun 26, 2014 10:30:52 GMT -5
Comments worth reading on this video
Post by TheAmishSasquatch on Jun 26, 2014 10:50:21 GMT -5
Thanks but IDK about the cutting the CDI. Seems a bit um... yeah.
Post by craisin on Jun 26, 2014 11:06:48 GMT -5
the blue CDI if you get a picture of it and view it fullscreen it has TZR50 on it does that ring a bell If you read all the comments on the previous video one guy give all the advance rates of the different colour CDIs And even if you suceed in derestricting a stock CDI you cant beat an aftermarket performance CDI designed for your type of engine 2t or 4t I should buy a performance CDI myself but i have a bigger bike also that needs money spent on it
Post by craisin on Jun 26, 2014 11:59:06 GMT -5
This video is a classic he thought he was having grounding problems with his CDI so he added a ground very interesting and easy to try being smart is not about your shoe size. And asking too many questions has its own set of problems eyes and ears will get you thru
Post by TheAmishSasquatch on Jun 28, 2014 13:49:34 GMT -5
So I tried removing the green wire. Scooter didn't even start. It actually nearly flooded the carb. I had to use the kick-start to clear it out and it sputtered to life on the 3rd-4th kick. My CDI is brown, and is about the size of a pack of cigarettes. It has the standard 2 & 4 prong setup. The 4 prong only has 3 wires in it. The fourth is completely empty with no signs that there was ever a wire in that port.
Post by craisin on Jun 29, 2014 19:01:00 GMT -5
Sounds like you have an unrestricted CDI if you want to go faster you need to change the final drive
Post by 2TDave on Jun 29, 2014 19:14:38 GMT -5
I've got a friend with a S9 and his cdi wasn't restricted.
Post by TheAmishSasquatch on Jun 29, 2014 19:41:47 GMT -5
Thanks guys. I'll check the manual and see what the factory gear is and go from there. I have an unrestricted boss coming in and an orange CDI. If all else I'll use it as a spare.
