Post by hppowdercoating on Sept 19, 2013 9:37:28 GMT -5
Here is my latest Scoot build.. Started out as a stock 2012 Tao Tao Palidin 150cc. Picked it up for $150 , had low miles but did not run. Got it home and Turned out it was only a lose plug wire.. i removed the 150cc setup ... Then after some cutting/welding to modify rear of frame and making new motor mounts here's the new Set-up.. Lowered 3" then Stretched 6" and installed a Water-cooled 257cc engine out of a Aeolus 260 scoot.. also powder coated wheels Gloss black and installed new 140/70/12 pilot power rear tire.. plus made and Ceramic coated my own exhaust..
Post by 90GTVert on Sept 20, 2013 11:10:53 GMT -5
Really cool project. Should be a lot of fun with the 260 in the small, low, frame. Where did you mount the radiator?
Post by hppowdercoating on Sept 20, 2013 14:38:00 GMT -5
Radiator is mounted just under front of the seat ..
Post by ryan on Sept 20, 2013 17:01:18 GMT -5
what guages you running
Post by Paladin on Sept 20, 2013 17:59:12 GMT -5
Here is my latest Scoot build.. Started out as a stock 2012 Tao Tao Palidin 150cc. Picked it up for $150 , had low miles but did not run. Got it home and Turned out it was only a lose plug wire.. i removed the 150cc setup ... Then after some cutting/welding to modify rear of frame and making new motor mounts here's the new Set-up.. Lowered 3" then Stretched 6" and installed a Water-cooled 257cc engine out of a Aeolus 260 scoot.. also powder coated wheels Gloss black and installed new 140/70/12 pilot power rear tire.. plus made and Ceramic coated my own exhaust.. Very nice, I have the same scoot same color and same year, got mine for 300 but it ran horribly with only 400km on the clock
Post by ryan on Sept 20, 2013 18:19:39 GMT -5
id pay couple grand for that
Post by hppowdercoating on Sept 24, 2013 15:55:33 GMT -5
Post by ryan on Sept 24, 2013 15:59:08 GMT -5
you powdercoat? i need some stuff done
Post by syko on Sept 30, 2013 5:12:05 GMT -5
how did you stretch the back end i've been looking for an extended swing arm cant really find any
Post by teddy554 on Sept 30, 2013 7:25:18 GMT -5
Nice work
Post by hppowdercoating on Oct 1, 2013 15:16:50 GMT -5
you powdercoat? i need some stuff done Yes I do. Email me at rnmhrd@charter.net
Post by hppowdercoating on Oct 1, 2013 15:18:48 GMT -5
how did you stretch the back end i've been looking for an extended swing arm cant really find any I had to make a new Swingarm mount..
Post by ryan on Oct 1, 2013 16:40:20 GMT -5
im also in the market for a stretch. id love one for a minarelli
