need help
Sept 24, 2013 12:16:31 GMT -5
via mobile
Post by tony38 on Sept 24, 2013 12:16:31 GMT -5
I have a ice bear maddog scooter ( Chinese) it has less than 500 miles and it stoped running. The engin(139 qmb) still runs and the belts fine but the rear wheel is now loss and it wont go. Lookin 4 some help
Post by 90GTVert on Sept 24, 2013 13:26:55 GMT -5
Welcome to the forum.
You mean the wheel is loose like it wobbles around... or does it not turn if the clutch bell is rotated? Does it rev up and not go or does it bog when you try to go?
need help
Sept 24, 2013 13:28:57 GMT -5
via mobile
Post by tony38 on Sept 24, 2013 13:28:57 GMT -5
It wobbles around and i accelerate and it wont go anywhere
Post by 90GTVert on Sept 24, 2013 17:49:01 GMT -5
First thing is to see why it's wobbling around and if anything is damaged that you can see from the outside. Is the axle nut that holds the wheel on loose? Do the splines on both the axle and the wheel look OK? Does the axle wobble?
need help
Sept 24, 2013 18:32:43 GMT -5
via mobile
Post by tony38 on Sept 24, 2013 18:32:43 GMT -5
Every thing looks normal from the outside but i couldnt get the wheel off to check the inside. I think is one of the gears that broke but i cant tell
Post by 90GTVert on Sept 24, 2013 19:11:45 GMT -5
If it all looks normal on the outside and the CVT looks OK, there's not much left. If you aren't already, try an impact wrench to get the axle nut off. Also try a penetrating fluid like PB Blaster or heating the nut (if you do both, remember that most penetrants are flammable).
Post by a2zjose on Sept 25, 2013 3:05:26 GMT -5
Hey ... We had the same problem with that model of bike... What is happening is the hub that holds the tire is braking at the welds and becomes off centered causing the the brakes to lock up...I would call the place you bought it form and have them replace it...of call ice bear directly and have them send you a replacement... Jose @ a2z Motorsports
need help
Sept 25, 2013 8:31:09 GMT -5
via mobile
Post by tony38 on Sept 25, 2013 8:31:09 GMT -5
Is that why i couldnt get the shock mount/exhaust mounts off
need help
Sept 25, 2013 11:55:23 GMT -5
via mobile
Post by a2zjose on Sept 25, 2013 11:55:23 GMT -5
Most likely... What we do in that case is use a prybar, stick it an the hole on the side and push the shaft out .... We were the first to sell the maddog in the US, very popular but lots of problems... We have addressed the company and they are working on getting them fixed
need help
Sept 25, 2013 19:08:22 GMT -5
via mobile
Post by tony38 on Sept 25, 2013 19:08:22 GMT -5
Thanks for the info how much labor at a shop do u think im lookin at, what other problems should i be aware of.
need help
Sept 25, 2013 23:37:54 GMT -5
via mobile
Post by a2zjose on Sept 25, 2013 23:37:54 GMT -5
No problem... We usually charge 1hr labor and get the parts under warranty...other than the hub crapping out we noticed a loud rattle coming from the metal plate under the seat..and the fact that is kinda slow
