Yeah it actually came with a fairly decent 4 page instruction leaflet, it's at my workshop so I can't post pics at the moment (it's 1:50am here), but I'll try to remember later on!
This is the seller I brought mine from, was the cheapest on Aliexpress at the time and the seller has great feedback.
s.aliexpress.com/7n2uyUrYKinda wish I'd gone for the black dial now!
I left the Suzuki loom standard, I had some plugs sitting around from the Sepia I parted so I depinned them and added them to the loom that came with the gauge so it just plugs in.
I actually removed the plugs that came on the gauges patch loom and after removing excess wires recovered the loom in braided conduit to tidy it up.
I removed all the wires for the gear indicators, water temp light, check engine light etc, but now I wish I'd thought to use the check engine light as my 2t oil warning!
Had to add a wire for the tach signal, according to the manual it can be taken from the pick up or from the coil, I couldn't get it to work properly from the pick up so added a wire to the coil output on the CDI plug.
Oh and I just tapped into the high beam switch and indicator power wires for the warning lights.
Fuel gauge works mint, even the low fuel warning light (which gets brighter the lower the fuel level)
You measure the rolling diameter of your front tyre and enter it into the gauge, the better you measure the more accurate the speedo ends up.
I need to remeasure mine, just thinking about it I did do a GPS comparison when I first fitted the gauge and it was within 3k, so I've just realized that the 80k in my video would be closer to 77k
Also fit as many magnets as you can fit on your disk for the pick up!!
Or at least 3 magnets anyway, I started with 1 and it's just not enough to give a decent stable speed reading!
Oh and the magnets I posted that I've used on mine with the alloy body and E-clips are not what come with it, it can't with plain little round neodymium magnets, I think they intended you to put them in the hex of the disk bolts, but they were too big for my bolts so I used the clip in magnets that came with the round gauge I got originally, that didn't work but at least gave me clip on magnets haha.
