Post by ivos on Jun 2, 2010 20:01:58 GMT -5
Hi guys, after 2 week of a work trip finally I have a time to come back to fix my vento. I resufaced the fuel tank by Kreem kit, worked pretty well, cleaned the carburetor, changed the battery... and it still wouldnt start. then I added a half turn of the mixture and then it finally started today. I have driven it for about 30 min. Then 2 hours later I cannot start it again. I suspect the Idle and mix. screws are not in the right possition, also I did move the bolt that makes the tension on the gas cable right by the carburator when i was cleaning it, i guess its not on the right place now.Do you have an idea how many turns those screws should go in? Btw. I live in florida...Thanx.
Post by 90GTVert on Jun 2, 2010 20:56:39 GMT -5
