w4adt
Scoot Junior
Post by w4adt on Oct 24, 2013 20:50:35 GMT -5
I'm Daniel, I'm new to the group and hope to learn a great deal, you never can learn too much. Here's my situation, besides not knowing the in's and out's of scooter engines, I need if possible someone to SHOW me how to change the gear oil and the motor oil - I have a 50cc Peace Scooter. It has 69 miles of which I've put 68 of those miles. I love my scooter, it's amazing fun, the helmet on the other hand, is very heavy, finally I'm getting use to it! I like in a small town outside of Braselton, Georgia I have just 4 months ago been diagnosed with bladder cancer, I'm NOT going to mope around feeling sorry for myself nor do I want anyone else to do that either, I want and intend to live however long I have, having fun and enjoying life to the best that I can.
Is there someone close by that can help me LEARN how to change the oil and gear oil? If so please email me directly at danielw4adt@gmail.com I do appreciate any help that can be given!
Daniel
Post by teddy554 on Oct 24, 2013 21:51:38 GMT -5
Post by aeroxbud on Oct 25, 2013 5:28:36 GMT -5
Welcome to the forum Daniel. It is quite a straight forward job to change the oil, You should have no problems.
w4adt
Scoot Junior
Post by w4adt on Oct 25, 2013 8:19:01 GMT -5
Thanks Teddy for the links, and now I am a bit more confused, I'm sure that you can clear the mud up a bit. My scooter says use GL-3 gear oil - so by the instructions given in the link, I can use 90 wt gear oil is that correct? And as far as the motor oil, I can use ANY 15W-40 motor oil, correct?
Daniel
Post by 90GTVert on Oct 25, 2013 9:08:43 GMT -5
Here's a vid showing both engine and gear oil changes... www.youtube.com/watch?v=CRVO6uRPJ2wYou can use any 15W40 engine oil. It does not have to be a motorcycle oil, because these scooters do not have wet clutches. I use 75W90, but any gear oil close to that will work.
w4adt
Scoot Junior
Post by w4adt on Oct 25, 2013 14:31:12 GMT -5
okay one last question today I found 20 W 50 can I use that?
Sent from my SCH-I605 using proboards
Post by 90GTVert on Oct 25, 2013 23:32:48 GMT -5
I don't know that thicker oil is a great idea with colder weather coming especially, but others do use 20W50. You can get Shell Rotella T 15W40 pretty cheap at Wal-Mart. I'd prefer synthetic, but I can't get Royal Purple/Mobil 1 for $13/gallon.
w4adt
Scoot Junior
Post by w4adt on Oct 26, 2013 13:34:21 GMT -5
that's what I needed to know I'm taking it back thank you for your opinion and suggestions
w4adt
Scoot Junior
Post by w4adt on Oct 26, 2013 21:20:23 GMT -5
that's what I needed to know I'm taking it back thank you for your opinion and suggestions Sent from my SCH-I605 using proboards Okay, someone please clear something up, I've seen this MANY PLACES - there is the OIL drain plug, and there is the filter drain plug - I assume that I only need to open the OIL drain plug then refill with out at the dipstick - I've also seen videos where they only drain the oil from the filter drain plug and NOT the oil drain plug, which is it!! Do one or do both? Daniel
Post by 90GTVert on Oct 26, 2013 22:08:42 GMT -5
If not messing with the "filter", just use the drain plug. If cleaning the screen I do both, but you could prob just do the filter side and tilt the scoot so oil runs that way.
Post by flqu06 on Oct 27, 2013 3:47:55 GMT -5
20w50 is thought to be tuff on the plastic oil pump gears. Also the 15w40s are quite good nowadays. Rotella being full of zink protects well. I prefer a synthetic blend at 10w40 for mine.
w4adt
Scoot Junior
Post by w4adt on Oct 27, 2013 8:50:11 GMT -5
thank you very much you answered my question
w4adt
Scoot Junior
Post by w4adt on Oct 27, 2013 18:06:47 GMT -5
nobody laugh! I took the plunge got everything ready had my oil had my final had my rags had my improvised oil pan. everything was going to cording to plan the oil drained out perfectly I waited to the last drop then cleaned around the drain plug put the plug back in tighten everything down went around to the other side of the scooter made sure the dipstick remain clean open up the bottle of oil inserted the final pour the oil here's where I took my time making sure I did not overfill everything registered fine I screwed the dipstick back in got on the scooter started the engine..the engine purred with the new oil inside I let the engine run for about 5 minutes checking every few moments for oil leaks none were seen none were to be found I thought damn I did a good job I did this all by myself..of course with the help of you guys of course! the old oil which believe me was very nasty and by the way not even a half a quart of oil was in the engine Thank God only put 60 miles on the engine before I noticed this! as I was saying pouring the nasty boy lol into a disposable container amazed at how dirty it was what was at the bottom of the dirty oil? you guessed it the washer that goes on the bolt plugging the oil.I could not believe it! so here I go again draining the fresh oil into a new container fishing out the washer shaking my head in disgust at my stupidity everything is now done all is complete no leaks I will once again check the oil level in the morning before I go riding! thanks to everybody I am now a professional scooter oil changer!!!!!!
Post by 90GTVert on Oct 27, 2013 18:32:55 GMT -5
Glad you got it changed and don't feel bad. That kinda stuff happens to all of us.
Post by oldsman on Oct 27, 2013 23:29:18 GMT -5
I forgot the screen one time. Boy was I a unhappy camper.
