Post by teddy554 on Nov 1, 2013 13:54:58 GMT -5
Traded my ruckus clone scooter for this eton beamer,installed mmmg bbk today and put my rs2 pipe on man this mmg kit might be the best 70cc iron kit i have ever used. I replaced all the missing screw and and got most the plastic connected together right but need a ignition this one is not the right one and has been rigged up also need the front plastic and headlight assembly if anyone has any of that for sale.Plan on putting my trition rims on it also.
Post by forde88 on Nov 1, 2013 20:16:02 GMT -5
Cool wee scooter has potential for sure
Post by oldgeek on Nov 1, 2013 20:26:15 GMT -5
Traded my ruckus clone scooter for this eton beamer,installed mmmg bbk today and put my rs2 pipe on man this mmg kit might be the best 70cc iron kit i have ever used. I replaced all the missing screw and and got most the plastic connected together right but need a ignition this one is not the right one and has been rigged up also need the front plastic and headlight assembly if anyone has any of that for sale.Plan on putting my trition rims on it also. Where did you buy the cyl kit from? I love the looks of those scoots myself.
Post by teddy554 on Nov 1, 2013 22:04:18 GMT -5
From modcycles you need a dealer account there to buy the kit, it is 89 buck everything include plus a wrist pin, if you want one pm me and ill order one for its 1295 shipping the also have lithium batteries for 35 buck with a 120 cca on the 4l-bs and 5l-bs replacement
Post by ryan on Nov 1, 2013 23:11:48 GMT -5
i also have a account through them, mario is pretty cool
Post by teddy554 on Nov 1, 2013 23:25:45 GMT -5
Yeah there all pretty helpful
Post by teddy554 on Nov 1, 2013 23:28:06 GMT -5
anyone know the spline count off hand for the final drive shaft for the 1e40qmb motor
Post by ryan on Nov 1, 2013 23:37:51 GMT -5
13 for input, i know hyosung and eton are alittle diff i think
Post by teddy554 on Nov 2, 2013 6:13:45 GMT -5
thanks
Post by 190mech on Nov 2, 2013 6:47:38 GMT -5
I had a Beamer,it had the small spline crank in it...Well built scoot!
Post by teddy554 on Nov 2, 2013 9:53:15 GMT -5
Yeah have to agree, i love them they are light and nimble also been wanting to get another after getting rid of my first one.
Post by teddy554 on Nov 2, 2013 14:39:04 GMT -5
Got the front tire swapped out but couldnt get the rear tire off my other motor its stuck like chuck tired wd-40 and heat and impact and breaker bar.
Post by teddy554 on Nov 3, 2013 12:39:54 GMT -5
Well the day went good and bad got new pads on the rear was in bad need of replaceming, and put my 12 in cpi rear rim on for now.The lower exhaust mount has been cracked and when putting exhaust back on i totally broke it off, not sure if i can get it welded on for a short term fix or not here is a washer/spacer eton need for the stock rim
Post by 90GTVert on Nov 3, 2013 13:04:15 GMT -5
Wow those shoes were rough. A good welder can weld these cases. 190mech and waltinhawaii have both done it. When I've tried to buy replacement case halves they didn't line up well. Maybe if you get an Eton part it would? It'd be worth checking with welders so you don't have to worry about finding 2 halves that match.
Post by teddy554 on Nov 3, 2013 13:11:50 GMT -5
Thanks 90GTVert ill start checking with the local shops i really dont want to have to split the motor, i have just hooked to the top mount now
