1flipflop
Scoot Junior
Avatar / Patch
Post by 1flipflop on Dec 3, 2013 1:57:33 GMT -5
Tried to go to website for E-ton scooter, etonamericaDOTcom not working? Anyone know why? Going to pickup my 2nd ever project ('09 E-ton sport 50) on Wednesday. Was bought from online police auction. Got it for a highest bid price of 32$ plus the warehouse fee $11.99 plus local sales tax total = $46.86 Had bookmarked etonamerica website , message box server not found pops up when trying to go there Plus when I go to a certain scooter parts website for E-ton sport 50 parts show a 2T engine for sale for this scoot supposed to be 4T misleading adds??
rupert
Post by rupert on Dec 3, 2013 3:11:58 GMT -5
*Tried to go to website for E-ton scooter, etonamericaDOTcom not working? Anyone know why?* Could be broken/out of service/bankrupt? Your guess would be as good as anyone elses'. Eton scooters are made by Jiee Industry ( www.ji-ee.com/en/index.php ) If you are really "stuck" (though I don't know why?) you can inquire at the Canadian distributor ( www.go4itsales.ca/about-eton.html ) *when I go to a certain scooter parts website for E-ton sport 50 parts show a 2T engine for sale for this scoot supposed to be 4T* Many Chinese scooters started out their product life as 2 cycle scooters. The EPA has put a stop to that and many models were silently upgraded(?) to 4 stroke engines. Many times, within a model line, the early ones were 2 cycle, and the later were 4 cycle.
1flipflop
Scoot Junior
Avatar / Patch
Post by 1flipflop on Dec 6, 2013 6:20:38 GMT -5
Hi, Thanks for the reply. Maybe could you tell me where i could see a wiring diagram for the 2009 E-ton sport 50. I do have the diagram for a sport 150 would that be same? I got this scooter just Wednesday 4th from a police auction, on the cheap too, possible was stolen B4 so the key switch was non functioning(vandalized key hole)there are 2 wires (from harness from frame) a red and a black that are spliced together, a female connector with 2 yellows and a green not connected(opposite side of ign. switch), the five wires (short harness from key switch w.male connector) not connected to anything and there is no female connector to connect it to?, front is damged from a spill?,scrapes and scratches but no cracks front wheel fender still good, headlight missing,, front (headlight mount) fender broke..at battery some wires are not connecting to neg. side.. pos. side all good was connection present. cdi wires were intact but there is 1 black 1 green white stripe 1 red small gauge wire just cut not terminated plus the larger gauge green wire same not terminated Thus when i try to test for spark there is no spark. Do you know a way to bypass, also would like to know should i get a spark if the battery was completely removed? There is a battery but try trickle charge doesnt seem to be any goo.
Post by moofus02 on Dec 6, 2013 6:35:10 GMT -5
Etons are quite often dc powered cdi. If the battery is junk you can hook up a charger so you have 12 volt to power cdi then kick and check for spark. This 2 or 4 stroke? Yahoo groups Eton had a beemer manual in the downloads of its 2 stroke that manual might help
1flipflop
Scoot Junior
Avatar / Patch
Post by 1flipflop on Dec 6, 2013 7:02:28 GMT -5
Etons are quite often dc powered cdi. If the battery is junk you can hook up a charger so you have 12 volt to power cdi then kick and check for spark. This 2 or 4 stroke? Yahoo groups Eton had a beemer manual in the downloads of its 2 stroke that manual might help Sent from my SPH-L720 using proboards 4stroke, Thanks for reply yes is DC needs power supplied? AC no? like a lawn mower flywheell passes coil? just posted reply from 1st reply, but will 150sport wiring diagramb same seems close but all i can find for now just got this scoot Wednesday 4th
1flipflop
Scoot Junior
Avatar / Patch
Post by 1flipflop on Dec 6, 2013 7:13:25 GMT -5
Got it for a highest bid price of 32$ plus the warehouse fee $11.99 plus local sales tax total = $46.86 Had bookmarked etonamerica website , message box server not found pops up when trying to go there Plus when I go to a certain scooter parts website for E-ton sport 50 parts show a 2T engine for sale for this scoot supposed to be 4T misleading adds?? All good now website back and Thanks moofus02 for the reply about the earlier models having 2T engines true thats why im sticking with the 4T now..
Post by moofus02 on Dec 6, 2013 7:21:21 GMT -5
rupert
Post by rupert on Dec 6, 2013 10:21:36 GMT -5
Post by fatboy on Dec 6, 2013 23:14:40 GMT -5
Post by scootertech on Jan 30, 2014 10:38:41 GMT -5
I was here checking to see if anyone else had seen that E-ton of USA has closed it's doors .
Post by fatboy on Jan 30, 2014 18:30:53 GMT -5
Eton he's no longer importing to stroke scooters only four strokes but if you need parts go to get2itsales.com I promise you there is nothing you won't be able to find on that website it is awesome
Post by etonbeamer on May 31, 2023 5:08:07 GMT -5
I got a 2009 eton beamer 50cc 4 stroke cant seem to get spark and thats right off the magneto pickup coil wire which is blue and white i get volts through the green and white wire mind you its a 3 wire magneto
