Post by nelson on Jan 20, 2014 15:50:04 GMT -5
my next question, since the flywheel side of my case is destroyed can i just buy that case half? I have done this with other engines and sometime they need a bit of work in the intake area. Do you guys see a problem with this?
Post by moofus02 on Jan 20, 2014 16:58:29 GMT -5
You could the match may not be perfect but it is doable
Post by 2strokd on Jan 20, 2014 17:42:05 GMT -5
Looks like it could be fixed without even taking the engine apart? I dunno, some of the cases weld real shitty tho
Post by nelson on Jan 20, 2014 21:22:23 GMT -5
Yea hopefully that is an option. Like doc said it is a toss up if it the material is stable enough to be welded. That is first option, second one is get another case half. Last is boat anchor
