Post by ohnobobo on Jan 13, 2014 11:54:19 GMT -5
My friend just recently upgraded from the 80-100cc BBK.... I rode it and want to cry, the thing pulls up-hill like ridiculously.
ALTHOUGH, he has ran into crank shaft problems actually broke one whole rod. Now he keeps having variator problems, because he insists of using such light-weight slider weights.
Everything aside, what would I need to do to make this a reliable daily?
Post by 90GTVert on Jan 13, 2014 14:17:00 GMT -5
If you want it to last consider a different crank. Something like the Naraku HD or maybe even a stock crank from a Kymco that has the 139QMB. You may get lucky and the crank will last, but an awful lot of people see severely reduced engine life with 50mm+ bores on stock Chinese cranks. I installed a brand new Chinese replacement crank with my 50mm kit and it lasted 2003 miles before the rod bearing went.
Keeping the revs a bit lower should help as well. Use rollers/sliders that don't make you redline all of the time. Maybe stick with a stock cam instead of an aftermarket piece that may push the powerband higher.
You still get a nice boost from a 47mm (72cc) kit and there have been far fewer stories of premature crank failure with those.
Post by ryan on Jan 13, 2014 14:26:55 GMT -5
unless your running a stroker max CC's is not over 89cc, stick with 47mm kit or 72cc and if you do go with a 50mm kit or 52mm kit its a must if you want reliability to get a hd crank by stated above. ive had kits that lasted only about 500 miles before going.
with 50-52mm kits i found that they work best with 1k torque springs and around 7.7.5g weights
Post by nelson on Jan 13, 2014 14:30:09 GMT -5
i have a 72cc kit for sale 75 shipped with 6gram dr slider sliders just saying...with aftermarket pipe. 100$ shipped
Post by ohnobobo on Jan 16, 2014 20:41:59 GMT -5
So overall I we can safely say that a 100cc BBK is ultimately a waste of money and will NOT be considered reliable what-so-ever.
Post by ryan on Jan 16, 2014 21:38:15 GMT -5
unless your dropping 150 for crank and another 50-100 on a good head...its a waste
ive completely decked out a 4t with all the stuff you can think of and it managed 55 tops and that was geared 52mm bbk variator stroked and cam/head to match and it was a wheelie machine but the top speed was only about 55-57 tops gps
Post by caliboy2010 on Jan 22, 2014 14:10:24 GMT -5
I've recently bought a Tao Tao ATM50-A1 and i got a 100cc big bore performance kit found here: www.ebay.com/itm/161018753179?item=161018753179&viewitem=&vxp=mtrI'm curious which other mods/upgrades I can buy to make this my daily driver and a fun little speeder. Money is not really an issue, neither is time, but I'd rather do all of the upgrades at the same time as the kit so I only have to do one dismantle and such.
Post by caliboy2010 on Jan 22, 2014 14:22:52 GMT -5
Like honestly you can throw a bunch of links at me and I'll check em all out and gladly accept any advice
Post by ryan on Jan 22, 2014 14:34:13 GMT -5
caliboy i can help you with all your needs message me and when i get back from a interview ill help you out
Post by 90GTVert on Jan 22, 2014 15:46:11 GMT -5
caliboy! As mentioned, a quality crank would be a good addition. Something like the Naraku HD should handle the added stresses better than stock. You can go with a stroker. PFS sells a 44mm Hoca stroker crank (part# 169-239). Scooters To Go sells one as well and they also sell a long block 87cc. Stroker cranks are not a drop-in item. They should fit, but clearances change when you change stroke so there's a lot to check over and a spacer plate may need to be made or the piston could need to be modified. The head looks to be pretty standard, basically stock with a little cutaway for the larger bore size. A big valve head would help. HERE is a cheap one from that same seller. PFS sells part #169-70 50mm big valve head. Scrappy sells a well reviewed head. NCY HERE. If you do go with a big valve head I would suggest port matching the intake manifold and spacer to it. I notice that kit comes with 1 jet and 1 set of roller weights. Consider a jet kit (PFS part# 114-49). I'd also consider a set of tuning rollers. Tuning rollers are not meant for long term use. You use them to find the weights that give you the best performance and then but roller weights to match. I prefer sliders, but the weights you find with rollers won't be the same as the slider weight you need for the same RPM so you may end up needed a couple sets of sliders in the neighborhood of 1g heavier than the rollers. PFS and Treatland are good sources for sliders.
Post by caliboy2010 on Jan 22, 2014 16:46:04 GMT -5
Thanks 90GTVert for the welcome! Thanks for all the advice, i'll take a closer look at the links and such after class and get back to ya.
Post by caliboy2010 on Jan 22, 2014 17:06:15 GMT -5
Well I'll definitely put in an order for the naruka HD crank for a start, and I'll see how the jet is on the kit i got off ebay with the 100cc big bore, since i already ordered that and it's on it's way. It's definitely going to be my weekend project when it gets here int he mail and i'll probably follow your PDI videos for a second time since i already did a watch through
Post by caliboy2010 on Jan 23, 2014 15:24:06 GMT -5
So i went ahead and ordered 1.5k clutch springs, 1k main torque spring, and some iridium spark plugs (2 to start), should i consider a 23mm bbk carburator? i found one on scrappydogscooters.com
Post by caliboy2010 on Jan 23, 2014 15:25:46 GMT -5
I also found this variator, should i get this one or do you recommend another?
Post by 90GTVert on Jan 23, 2014 16:59:35 GMT -5
You don't need a larger carb for the 50mm kit. The vari is a good deal. Hard to go wrong at the price.
