stoop
Post by stoop on Jun 24, 2010 17:06:36 GMT -5
i still dont have electic start on my scooter and im going to attempt to figure out why... i was rummaging through the garage, and i found this is an old toolbox i dont know what setting to put it on to measure what i need to measure? will this even work for what im doing?
Post by Goosey on Jun 24, 2010 17:13:24 GMT -5
Did you ever change the relay?
stoop
Post by stoop on Jun 24, 2010 17:30:54 GMT -5
Yea.
Post by andsetinn on Jun 24, 2010 17:43:35 GMT -5
Fluke meters are very good meters. If it will work for what you're doing depends on what you're doing. - Off means, well, off. - V~ means AC Voltage, automatic scale. - V= means DC Voltage, automatic scale. - V=300mV means all DC Voltage under 0.3 volts. - The horseshoe is Ohms or resistance. - Then you get diode checker with buzzer. - A~ is AC current, automatic scale. - A= is DC current, automatic scale.
To measure voltage in your scooter you set the meter to V=. Measure voltage across the starter terminals while trying to start the scooter. If there is 10-14 volts, but no movement, while trying to start, then the starter is faulty. Measurements of other components are just as easy but harder to find where to measure. :riding:
