Post by andsetinn on Jul 3, 2010 12:45:20 GMT -5
I found those links while browsing the net and thought I'd share them. If this is in the wrong section please relocate it. First, Scooter-puter www.janspace.com/b2evolution/arduino.php/2010/06/26/scooterputer. This guy has built a beautiful computerized scooter dashboard from Arduino (easily available programmable computer on a chip) and some accessories. Originally it was meant to monitor voltage, but he added features like GPS, temperature, lean and speed indicators among others. Second, Java-pipe. www.mh-aerotools.de/airfoils/javapipe_en.htm. A Java program to calculate dimensions of tuned pipe for 2 stroke engines. You type in at what rpm you want the pipe to hit, what your engine size is and what fuel you're using. The program will then give you all dimensions you need to built that pipe. This does not work on Microsoft explorer or web browsers with old Java.
Post by 90GTVert on Jul 3, 2010 15:26:28 GMT -5
That scooterputer is impressive! Thanks for sharing.
