Post by zukimoo on Apr 14, 2014 17:52:59 GMT -5
Hey I got a 06 PGO Trex 50cc and my daughter drives it around. The speedo goes right up to 70km/h right after you take off and it stays up there. Sometimes is looks like it's working good but I know I'm not going 70km/h.
The thing is amazing and a blast to drive but she needs to see her speed. We just pulled it out and getting new tires and the snow is almost gone so she will be wanting to ride.
I also got no flashers but still trying to figure that out.
Post by Upgrayedd on Apr 14, 2014 17:55:56 GMT -5
great thread title
Post by 190mech on Apr 14, 2014 20:01:47 GMT -5
Post by 2TDave on Apr 14, 2014 20:10:46 GMT -5
Welcome aboard!
Post by zukimoo on Apr 14, 2014 21:12:30 GMT -5
I had the same system on my bicycle when I was into cycling and it worked great. Do people just head to these right away because we can't fix the stock speedo?
I'd like to keep the scooter clean for her and not worry about someone stealing the gadgets.
Post by Upgrayedd on Apr 14, 2014 21:19:04 GMT -5
I had the same system on my bicycle when I was into cycling and it worked great. Do people just head to these right away because we can't fix the stock speedo? I'd like to keep the scooter clean for her and not worry about someone stealing the gadgets. if you can figure out how far off the speedo is by using a gps (some cell phones have them built in) for speed/mileage comparison, you might be able to get it real close by changing the front tire size. www.tacomaworld.com/forum/tirecalc.phpim running my stock tires to get my use out of them, but i already know how far off my speedo reads so i plan to run a taller front tire to correct mine when this tire is used up. same price, same width as rear, fixes speedo
Post by dan50 on Apr 14, 2014 23:06:00 GMT -5
Welcome to the forum!
Chinese speedometers are garbage. They must all have the same ratio. All 3 of my scooters are way off. Like I've said before, the Chinese aren't good enough at math to make an accurate speedometer. Even if you buy a stock replacement, it probably will still be off. Aftermarket is the way to go if you want accuracy.
Post by oldsman on Apr 15, 2014 0:19:39 GMT -5
I also got no flashers but still trying to figure that out. To answer your question . If you start out slow and it jumps right up there It is the speedo cluster itself.
Post by aeroxbud on Apr 15, 2014 5:05:05 GMT -5
Welcome to the forum. Is it digital or cable operated?
Post by Sitticuss on Apr 15, 2014 11:17:29 GMT -5
I agree its the cluster. you can probably score a replacement on ebay. they are accurate enough for normal use. You can unscrew the cable from the back of the unit and spin the front tire to make sure the cable turns also. Usually when it does what your saying the cluster is bad.
