Post by 49cc High Country on Apr 15, 2014 16:38:10 GMT -5
I changed out my gas lines to some blue clear ones. I notice there is air (a lot) in the line between all the connections; ex: after the filter, between the pecock and carb. Is this normal? On my way to work the scooter ran fine but on my way home, it stalled out 3x's. I was able to mess with the carb and get it start...go a block and died. Bypassed the pecock, got it started and went another block before it died. After the third time I gave up and walk the scooter home. Something tells me that the air in the lines if messing thing up. Please Help!
Post by flqu06 on Apr 15, 2014 17:44:30 GMT -5
Its normal
Post by 49cc High Country on Apr 15, 2014 18:07:28 GMT -5
I got it running. I noticed my air filter was really dry, so I took it off and allowed the air to escape and filled up the filter with gas and put it back on. Then some of the air down hill from the filter flowed upward into the filter so it is now half full with gas. So far so good. Yes, there is still some small air bubbles in the lines but not as big as they where before.
Gas Lines
Apr 15, 2014 18:25:04 GMT -5
via mobile
Post by apescoot05 on Apr 15, 2014 18:25:04 GMT -5
i have ridden it. It takes off fine. No issues with start up or anything like that if i let off the throttle to slow down or stop that's when it dies
Post by 49cc High Country on Apr 16, 2014 7:03:10 GMT -5
i have ridden it. It takes off fine. No issues with start up or anything like that if i let off the throttle to slow down or stop that's when it dies Have you tried to adjust your carb yet?
