Post by ankfoot on Apr 28, 2014 12:03:23 GMT -5
Hi!
As the topic says.
I have a collegue at work who has some type of Linhai-scooter with an engine where this code is stamped to the cylinder 1E40FM.
I've read that it's a longer stroke than 140EQMB or the normal minarelli clones..
Does a normal exhaust fit or is the measurements between exhaust port and mountingbracket off?
thanks!
Post by moofus02 on Apr 28, 2014 12:16:18 GMT -5
Exhaust should fit might take a little finessing. Bbk might be hard to find because they use basically 90cc cases with a longer stroke than the standard 49cc stuff. They will take a 54mm Cylinder kit without machining but have a 10mm piston pin so to build a big motor you need to change the crank the good news is the 45mm cranks and 54mm cylinders will drop right in to make a 103cc Street motor.
Post by usmcdoc on Apr 28, 2014 12:23:29 GMT -5
The 1E40FM as moofus02 said is an easy adaptation to 90cc..The FM motors are rare..would love to find one..
Post by moofus02 on Apr 28, 2014 12:29:48 GMT -5
The FM motors are rare..would love to find one.. Me too Sent from my SPH-L720 using proboards
Post by moofus02 on Apr 28, 2014 12:31:22 GMT -5
Tell him it's an orphan and offer to take it off his hands lol
Post by ankfoot on Apr 28, 2014 14:48:23 GMT -5
I've read up on that 90cc possibilities, sounds pretty cool =) If one were to get hold of this little engine, and make a little project, just for fun Looks somewhat rusted I must say, probably been stored outside under some shed. I should read the thread 90GTVert made about the topic. I guess there are regular 90CC exhausts for the atv's? if one would make such a conversion.
Post by 90GTVert on Apr 28, 2014 15:19:23 GMT -5
You can't use an ATV exhaust. Totally different routing for the pipe to work on an ATV vs scooter.
Post by ankfoot on Apr 29, 2014 1:34:46 GMT -5
Hehe, of course, my brain was in my pocket there..
Post by vade420 on Aug 23, 2019 16:37:43 GMT -5
