Post by AlexF2294 on May 1, 2014 14:32:52 GMT -5
What are the differences between an open air filter and an airbox type air filter? I know it's louder with an open filter but what about performance?
Post by 90GTVert on May 1, 2014 15:02:53 GMT -5
The gain is usually noise. I quit using pod filters when I realized I was getting the same results with stock airboxes. Even on larger carbs a stock air box with the snorkel removed will work. Don't remove the snorkel when using a stock carb though, because then you're just causing yourself more jetting and tuning issues than you need.
Post by AlexF2294 on May 1, 2014 15:22:13 GMT -5
And how can I measure my carb size if my caliper doesn't fit in there
Post by AlexF2294 on May 1, 2014 15:34:49 GMT -5
Is it bad if there's oil in my airbox?
Post by 2TDave on May 1, 2014 16:52:57 GMT -5
Use something you can get in there and measure it. A piece of solder bent maybe.
Post by AlexF2294 on May 1, 2014 17:09:07 GMT -5
I only have a 14mm carb...
Post by Sitticuss on May 1, 2014 17:48:14 GMT -5
I only have a 14mm carb... 14mm sounds about right. a little oil in the airbox is normal.
Post by Upgrayedd on May 1, 2014 17:50:46 GMT -5
I only have a 14mm carb... 14mm sounds about right. a little oil in the airbox is normal. for sure. i keep my air filter oiled
Post by AlexF2294 on May 1, 2014 17:51:14 GMT -5
Will that still be big enough with a BBK?
Post by Sitticuss on May 1, 2014 17:53:33 GMT -5
I'm using one on my 90cc with a 54mm BBK. It Works fine.
Post by 2TDave on May 1, 2014 17:54:50 GMT -5
I don't think so. Most say a minimum 17mm and a 19 is preferred.
Post by AlexF2294 on May 1, 2014 17:55:28 GMT -5
14mm sounds about right. a little oil in the airbox is normal. for sure. i keep my air filter oiled  I mean, I oil the filter on my RC car....
Post by 2TDave on May 1, 2014 17:55:48 GMT -5
Guess I'm wrong. Seems small.
Post by AlexF2294 on May 1, 2014 17:56:11 GMT -5
I don't think so. Most say a minimum 17mm and a 19 is preferred. Not even with a huge jet? Haha
Post by Sitticuss on May 1, 2014 17:58:06 GMT -5
My carb is stock.... Its called a 19mm carb but if you actually get in there and measure....its not really a 19mm.....
