Post by 90stanggt on May 14, 2014 22:06:56 GMT -5
Can I swap a short case engine in place of a long case engine (2 stroke vento)?
Post by moofus02 on May 15, 2014 4:23:50 GMT -5
It's been done. Someone here put a shortcase 90 in a longcase bike and Ryan had a shortcase bike with a longcase in it. Not a perfect option but doable
Post by 90GTVert on May 15, 2014 21:40:08 GMT -5
It's probably gonna look weird with a small tire on the back and shortening the wheel base, but should work.
Troll
Fastest 50cc in Upstate SC
Post by Troll on May 15, 2014 21:47:39 GMT -5
I did a long case on a 4T once looked bad ass with the 10 in front and a 12 in the back, looked like it had a fatty on it.
Post by twowheelinjim on May 17, 2014 21:21:52 GMT -5
I recently swapped a short cased 150 with a long case 150. It was more of a necessity than a fun project. I had to get a scooter running and all I could find was a donor scooter that was wrecked. It didn't even dawn on me that it was a long case until I tried installing the original exhaust pipe. When the engine was finally installed in the frame, the shock had a bit more angle and the scooter appeared to squat a little more. The owner was pleased with the new appearance as it now kind of looked like it was customized. The larger wheel from the long case had to be used since it was a disk brake rear. It's been on the road for about 6 weeks and as far as I know, it's still working normal.
Post by 90stanggt on May 17, 2014 21:34:21 GMT -5
I can get a running 70cc S/C for a decent price, I just can't seem to figure out what is going on with my l/c.
Troll
Post by Troll on May 18, 2014 7:07:26 GMT -5
I recently swapped a short cased 150 with a long case 150. It was more of a necessity than a fun project. I had to get a scooter running and all I could find was a donor scooter that was wrecked. It didn't even dawn on me that it was a long case until I tried installing the original exhaust pipe. When the engine was finally installed in the frame, the shock had a bit more angle and the scooter appeared to squat a little more. The owner was pleased with the new appearance as it now kind of looked like it was customized. The larger wheel from the long case had to be used since it was a disk brake rear. It's been on the road for about 6 weeks and as far as I know, it's still working normal. With it having disk in the back did you have to change out the brake lever?
Post by 90GTVert on May 18, 2014 9:46:51 GMT -5
That does look cool Troll. Any clearance issues on the scooter? Since that scoot is so small it reminds me of the look of the larger ones that use a 16" wheel... which I like, but they can't always fit a real seat bucket.
Post by twowheelinjim on May 18, 2014 10:38:01 GMT -5
Hi Troll, I had to shave off the cable lever mount off of the left controls. The rear brake master cylinder fitted nicely in it's place. At first I tried to simply rotate the controls to make space but it really was better to just cut off the remaining lever mount.
Troll
Post by Troll on May 18, 2014 19:38:51 GMT -5
That does look cool Troll. Any clearance issues on the scooter? Since that scoot is so small it reminds me of the look of the larger ones that use a 16" wheel... which I like, but they can't always fit a real seat bucket. There was no issues, already had the rear fender chopped off but besides rainy days it was fine.
