Post by Deleted on Aug 8, 2010 17:03:46 GMT -5
Long time i try to found my caburator problem! I have a 72cc kit, original air box and a Tecno exhaust. I have a Pilot jet #35 and a main jet #85 and my spark plug is always dark black (too Rich)!? I play with the mix air screw, now is at 1 1\2, my idle is #1. My valve are set at .003mm Intake and Exhaust. When i accelerate, slow down and re-accelerate the motor hesitate all the time and when i slow down the muffler make a small (Pfft) not a real backfire.... The top speed il have is around 43~45 mph. Is it possible is the choke always on and it make always rich!?Normally we suppose to use main jet #90 or more with a 72cc kit. My scooter is a Kymco People 50S 4T (gy6)
Post by Goosey on Aug 8, 2010 19:11:32 GMT -5
The air mix screw and idle adjustment affects how your scooter idles. Shouldn't affect your acceleration. I just have to check you on that valve setting. If you are using a guage for "mm" you should be at .03mm, not .003?
