Post by scooterpimp on Apr 8, 2019 4:37:50 GMT -5
Snuck in a ride Sunday afternoon , felt good getting fresh air .
Post by scooternub on Apr 8, 2019 6:56:09 GMT -5
Snuck in a ride Sunday afternoon , felt good getting fresh air . That and that spring is def. here, its been perfect weather.
Post by sToRm on Apr 8, 2019 15:11:48 GMT -5
Got a couple more Tags before the rain spoiled everything.
Post by 2stroked on Apr 8, 2019 16:32:53 GMT -5
Started to take dudes bike back last night. Realized he had no tail lights, brake lights or turn signals. Well fuck.
So today I traced the wires, and discovered the PO had butchered the harness in such a way that the ground tab for the light sockets was getting 12v positive at all times. Not when the engine was running or the key on, but all. The. Time....whoa. Ten minutes some tape wire nuts and dummy light, he has his bike back. Most if yesterday was lost to rain, so we talked and decided to split the $50 difference....yay me.
rareanimal
Post by rareanimal on Apr 8, 2019 20:11:58 GMT -5
Blew my top end today after hitting 54mph downhill, clouds of smoke, power quickly went away and bogged to a stop. Still turns over freely but won't start. Getting fuel and spark so I am guessing it's the exhaust valve. Already ordered a new engine, nothing special same cc same setup, looks plug and play. Am going to keep it legal for now. I want to rebuild this one as well maybe soup it up a lil.
Post by aeroxbud on Apr 9, 2019 15:09:30 GMT -5
Started to take dudes bike back last night. Realized he had no tail lights, brake lights or turn signals. Well fuck. So today I traced the wires, and discovered the PO had butchered the harness in such a way that the ground tab for the light sockets was getting 12v positive at all times. Not when the engine was running or the key on, but all. The. Time....whoa. Ten minutes some tape wire nuts and dummy light, he has his bike back. Most if yesterday was lost to rain, so we talked and decided to split the $50 difference....yay me. Oh, it's gone home. No more daily updates. Was enjoying this series
Post by aeroxbud on Apr 9, 2019 15:11:34 GMT -5
Blew my top end today after hitting 54mph downhill, clouds of smoke, power quickly went away and bogged to a stop. Still turns over freely but won't start. Getting fuel and spark so I am guessing it's the exhaust valve. Already ordered a new engine, nothing special same cc same setup, looks plug and play. Am going to keep it legal for now. I want to rebuild this one as well maybe soup it up a lil. Will be good in the long run to have one standard motor. And one modified one. Always good to have a backup
Post by collinsd84 on Apr 10, 2019 17:11:44 GMT -5
Peeked in the shed to make sure it was still there with a promise to ride next weekend. My job is keeping me busy right now. The traffic is horrendous in my neighborhood, hence the rerouting of 421. Looking forward to a ride...
rareanimal
Post by rareanimal on Apr 10, 2019 22:46:54 GMT -5
Well, I opened her up and found the head gasket blew. I'm guessing the loss of power is due to that and the material leaving the gap slowly reduced compressione but not sure it was the culprit for the smoke prior to the failure. Upon pulling the sleeve I noticed all the grooves were lined up on the rings, maybe that let some by.
Post by 2stroked on Apr 11, 2019 16:57:19 GMT -5
Well hell. The guy that I rebuilt the 150 for showed up today with an 07 Honda 80 something or another. Bad base, head, and valve covet gaskets. Bad intake gasket, leaking oil from every possible orifice. I feel like I should shoot it to release its suffering.
There was a can of ether in the front compartment, so that's a baf sign. Pulled the carb shot some ether into the intake and tried to start it. Not even close. Its got 48 psi compression so I figure a co olete tear down and rebuild. Nope.... Owner is flat ass broke, and begged me to hill billy engineer it back to running as its his only mode of transport. The friend with the 150 has agreed to pay for my time and matetials, so long as I can get it going before Monday, and don't have to order anything.
Got it tore down, and the rings/piston look good, valves are sealed right. Idk, I'll give it some gaskets, some love, and try again. Oh well. Gibes me something to do on my down time ...
jaybird
Post by jaybird on Apr 11, 2019 18:00:59 GMT -5
I had some parts arrive, header bolts, spring kit and the (finally correct size) drive sprocket.
Post by 2stroked on Apr 12, 2019 15:57:35 GMT -5
I'd LOVE to find the genius engineer at Honda that developed this shitty 80 and kick him in the balls. Hard. Like really hard. The carb is retarded difficult to mount/remove with the engine in the bike, the exhaust wraps around the damn head...this thing is just wrong....ugh, and of course it doesn't share a common bore with anything I have access to in person so I have to wait a couooe weeks for damned rings. At least the engine goes in/ comes out with two bolts. That's this things only redeemable quality...and its not even a great thing....
dotdash
Post by dotdash on Apr 16, 2019 11:22:05 GMT -5
Swapped the clutch at Lowe's cause the primary one is stuck and not expanding. Many Lyfts later and missing work.... 😑
Post by milly on Apr 16, 2019 11:42:27 GMT -5
Put ratfink on ebay today. Hopefully a new owner buys it.
Post by spazter12 on Apr 16, 2019 11:51:05 GMT -5
Swapped the clutch at Lowe's cause the primary one is stuck and not expanding. Many Lyfts later and missing work.... 😑 Dude I feel like sometimes it's more of a hate than a love relationship with our scoots but in the end when they work everything is forgiven lol
