Post by aeroxbud on Jun 26, 2014 3:50:58 GMT -5
Just off to do a little prep work then under coat on some panels
Post by craisin on Jun 26, 2014 4:42:23 GMT -5
purging water from carb rev hard method
Post by Clank on Jun 26, 2014 7:51:14 GMT -5
purging water from carb rev hard method Huh???... Wha??¿. . . Water, Carb, Hard Method? That's four words that should never be in the same conversation, let alone all in the same sentence. . . You got a "Kiwis to Western English" translation link, cause Google Translation doesn't have that?. . Don't worry, I sent a email requesting it to be added. . .
Post by craisin on Jun 26, 2014 18:00:21 GMT -5
Post by TheAmishSasquatch on Jun 27, 2014 13:26:02 GMT -5
Filled it, rode it, washed it; about to wax it
Post by craisin on Jun 27, 2014 13:46:28 GMT -5
Filled it, rode it, washed it; about to wax it Nice looking scooter
Post by TheAmishSasquatch on Jun 27, 2014 13:55:27 GMT -5
Thanks.
Post by stevec on Jun 27, 2014 18:03:21 GMT -5
Today i replaced the cluster bulbs with blue ones, now it lights up the red numbers purple, looks really cool.
Post by craisin on Jun 27, 2014 19:02:05 GMT -5
Today i replaced the cluster bulbs with blue ones, now it lights up the red numbers purple, looks really cool. When you say cluster bulbs is that like dash lights?
Post by 2TDave on Jun 27, 2014 20:08:01 GMT -5
Started tearing down a motor that came today for a new build. Well it's for my scooter and my scooter sat quietly watching but I can feel it's a little anxious. Lol
Post by FrankenMech on Jun 28, 2014 4:04:12 GMT -5
I got to rescue a gorgeous young damsel in distress on a Taotao 50cc scooter with starting problems. -Not bad for an ugly old knight in rusty armor.
The electric start works now and her battery seems to be charging. The voltage did not get up to the float voltage of 13.8-14.2V while I worked on it. There is still something wrong with her kick starter. It jams and will not return to the horizontal position unless it is wiggled around with some force. It is a fairly new scoot with 2000 something on the odometer.
She makes a long 40 mile commute to work but at least she knows a way-station midway along her ride where she can get help now. I gave her an auxiliary fuel bottle to use also. Those stainless steel water bottles with a new O-ring work good for seeing if there is any murkiness from water in the fuel also. Dump the bottle in your tank and pump some fuel into it and examine it. If it is milky or anything go to another station.
Post by craisin on Jun 28, 2014 4:33:15 GMT -5
I got to rescue a gorgeous young damsel in distress on a Taotao 50cc scooter with starting problems. -Not bad for an ugly old knight in rusty armor. The electric start works now and her battery seems to be charging. The voltage did not get up to the float voltage of 13.8-14.2V while I worked on it. There is still something wrong with her kick starter. It jams and will not return to the horizontal position unless it is wiggled around with some force. It is a fairly new scoot with 2000 something on the odometer. She makes a long 40 mile commute to work but at least she knows a way-station midway along her ride where she can get help now. I gave her an auxiliary fuel bottle to use also. Those stainless steel water bottles with a new O-ring work good for seeing if there is any murkiness from water in the fuel also. Dump the bottle in your tank and pump some fuel into it and examine it. If it is milky or anything go to another station. Good on you well done
Post by stevec on Jun 28, 2014 4:56:23 GMT -5
Today i replaced the cluster bulbs with blue ones, now it lights up the red numbers purple, looks really cool. When you say cluster bulbs is that like dash lights? Yes, the dash lights, uses 194 bulbs
Post by 2TDave on Jun 28, 2014 5:26:06 GMT -5
Nice work Franken!
Post by craisin on Jun 28, 2014 7:26:18 GMT -5
[img src=" i.imgur.com/MwmibNe.jpg" src=" " alt=" "] are these ideal to make a 2t water cooled minarelli no water pump required too much optimitic vegetation
