Post by zerotothirty on Feb 26, 2024 22:18:36 GMT -5
I installed a Naraku 50cc top end yesterday and let the silicone cure overnight. Took it out and started it up and could hear something off right away. I'm not sure what the problem is yet, but I did a compression test after letting it idle and revving it a few times. 50 psi. Even worse than the fried Malossi I was replacing. There are metal shavings in the spark plug. So, I rode my bicycle to class today!
Post by milly on Feb 27, 2024 1:12:37 GMT -5
What purpose does this thing serve circled in red on gy6 150cc?
Just going through starting problem solving, fuel, spark good, just another thing to check before multimeter out again. All it does is loop round to the silver blob and have a small plastic one way? valve bottom right of pic. Hopefully removing it will show if needed or not 😕
Post by aeroxbud on Feb 27, 2024 4:17:50 GMT -5
I installed a Naraku 50cc top end yesterday and let the silicone cure overnight. Took it out and started it up and could hear something off right away. I'm not sure what the problem is yet, but I did a compression test after letting it idle and revving it a few times. 50 psi. Even worse than the fried Malossi I was replacing. There are metal shavings in the spark plug. So, I rode my bicycle to class today! Did you check the squish band? Rings not seated correctly?
Post by zerotothirty on Feb 27, 2024 9:44:49 GMT -5
I installed a Naraku 50cc top end yesterday and let the silicone cure overnight. Took it out and started it up and could hear something off right away. I'm not sure what the problem is yet, but I did a compression test after letting it idle and revving it a few times. 50 psi. Even worse than the fried Malossi I was replacing. There are metal shavings in the spark plug. So, I rode my bicycle to class today! Did you check the squish band? Rings not seated correctly? I just did some googling, this definitely could be a culprit. The jug and the head were sold separately on scootertuning. Is it normal to have to measure and verify kits new out of the box? Maybe I was naïve to figure it was plug and play.
Post by milly on Feb 27, 2024 10:59:54 GMT -5
Removed blob and linked up both lines into one. On assembly noticed clear liquid in pipe from valve cover to airbox, removed pipe fair bit of water came out. Carried on putting together and inserted air pipe on carb without clip to see if ran okay and did. Need to remove panel to clear airbox and couldn't be arsed today. That can wait till next time as could be soaked in there, not sure how but who knows with a scooter only doing 50 miles in 7 years before I got it.
Post by aeroxbud on Feb 27, 2024 15:53:12 GMT -5
Did you check the squish band? Rings not seated correctly? I just did some googling, this definitely could be a culprit. The jug and the head were sold separately on scootertuning. Is it normal to have to measure and verify kits new out of the box? Maybe I was naïve to figure it was plug and play. You should always check to be safe. It also lets you know if it needs to be adjusted.
Post by aeroxbud on Feb 28, 2024 6:11:26 GMT -5
Post by milly on Feb 28, 2024 6:42:18 GMT -5
Today removal of rear. Quite impressed how quickly it came off. Let's see how it goes back on again once sorted air box if that's the problem all along. 😁 To busy booking schools this afternoon, the only one that answered this morning booked me for a puppet show instead.
Post by scooterpimp on Feb 29, 2024 11:23:15 GMT -5
Well I’m not one to brag …. But … I charged my Battery 😂😂😂
Post by milly on Feb 29, 2024 12:37:25 GMT -5
Engine sorted at last now air filter has been stripped of its pre filter, foam around the main paper filter and the damn snorkel. Starts first time every time.
Post by FrankenMech on Feb 29, 2024 16:05:13 GMT -5
Make sure you don't have your pink panties in the picture when taking pics of the scoot. That is almost as bad as taking a selfie with a container of anal lube in it. LOL
It is amazing how the simple things can screw up a scoot.
Post by milly on Mar 2, 2024 12:23:29 GMT -5
Today was sorting out the garage, unit and shed to make way for scooter and motorbike, plus Yolanda's mobility scooter.
Post by aeroxbud on Mar 2, 2024 17:06:40 GMT -5
Today was sorting out the garage, unit and shed to make way for scooter and motorbike, plus Yolanda's mobility scooter. You have a pit bike now Milly? Be pulling wheelies round the council estate next. 😂
Post by Wrenchturner on Mar 2, 2024 18:54:37 GMT -5
I didn't do too much, but I charged the battery, slapped on my registration decal and swapped the factory engine oil for 10-40. I also installed that aluminum fuel filter I bought....but it's like 2 1/2 times bigger than the stock, so I'll keep it just in case I messed up.
I may want to swap out those stock fuel lines after all, something just tells me I should put that on a to-do list.
Post by milly on Mar 2, 2024 19:03:02 GMT -5
Not mine aeroxbud belongs to a friend's son. I delivered it back today.
