Post by 2strokd on Aug 21, 2010 7:00:23 GMT -5
All give ya a call this weekend shakerdriver! I might have some stuff here that will wake er up a bit!?!
You can try stiffer clutch springs, but some thought must be put into that also... If you go too tight on the c/springs the engine will spin the pulleys right past "first gear" before engaging. Then you end up reving just to bog even worse when the clutch kicks. However, the right combo for your scooter can really bring out the best in the lil engine!
