Broken commandment; home drilled 85 main jet. Walmart.
Jul 3, 2014 23:45:04 GMT -5
TheAmishSasquatch likes this
Post by niz76 on Jul 3, 2014 23:45:04 GMT -5
Hi fellas (and ladies-I'm sure there are some ladies here right??)
I broke one of the ten commandments of scooter tuning; "Thou shalt not drill his own jets" lol.
Unfortunately my info here isn't very precise and I cannot locate the references.
During a 2am binge of forum reading and Brent's youtube videos I just couldn't wait until tomorrow to get some bigger jets for my carb to go along with the shiny new expansion pipe that came today and I installed. I did some googling and found some conversion info about main jet sizes to inches, mm, etc. Somehow I surmised that it takes a 1/32" precision drill bit to equal an 85 main jet size for 1pe40qmb minarelli stock carb. Since then- I've learned on this forum that main jet sizes differ in measurements, flow rate, etc. from different manufacturers. Like I said, this tip isn't precise in the all the info but it worked out great for me.
I found a precision drill set at Walmart- 2am scooter tuning headquarters haha- made by Dremel. The smallest bit in the set is 1/32". I carefully chucked it in my drill and- I believe this is the most important part- drilled the main jet out with the drill in REVERSE. I did this to avoid the bit biting in too aggressively in the soft (brass?). While holding the drill as straight as possible I started out slowly at first, but realizing I was moving around too much to get a precise hole, I ended up squeezing the trigger in a quick burst and it easily went through in one quick motion.
I realize this isn't advised and that jets are very cheap etc. However, I did this about a month ago and it's worked out great for me. It just happened to be perfect fuel flow for my setup and my scoot is a dependable daily driver and runs like a top. I still currently have this main jet installed.
Simple Trick but I though this might be handy for the guy (or gal) wanting to up main jet size at 2am. Everyone is a scooter ride away from a Walmart right?
