Post by scooter2828 on Jun 12, 2015 21:38:28 GMT -5
Question has anyone tried sitting on the scooter and it wont start but if the stand is in it starts
Post by scooter2828 on Jun 13, 2015 0:03:33 GMT -5
I know i need a new floater pen im going to just get a new carb i start it with out sittingbon it but when i but when i put it on its wheels and sitvon it it doesnt start im hoping that just has to do with the floater
Post by 90GTVert on Jun 13, 2015 6:59:07 GMT -5
Could be float height related because of changing angle. Some scoots have sidestand kill switches, but that does the opposite and they won't start with the stand down.
Post by scooter2828 on Jun 13, 2015 12:50:29 GMT -5
Yeah not the kickstand the other one when you need to work on it ot starts up just when its on its wheels it doesnt want to start im goibg to get a new carb
Post by scooterpimp on Jun 13, 2015 12:59:28 GMT -5
Center stand saftey switch
Post by scooter2828 on Jun 13, 2015 13:23:06 GMT -5
If tbe floaters bent would that be one reason its not turn over when its not on the stand i no the floater pen is bent im getting the carb on friday i replaced the ignition coil the one i had was good i just want to geg the parts and fix it up so its a good working scooter
Post by scooter2828 on Jun 13, 2015 13:26:46 GMT -5
It the engine sounds good we get it started perfect when its on the center safety stand when we drop it down it doesnt start i know you said about the floater i webt to a scooter shop he said could be more wrong with it but if its the floater which im just gonna replace the carb seeing as at that scooter shop they dont have carb kits
Post by scooter2828 on Jun 13, 2015 14:43:15 GMT -5
The back tire spins when you start it should it do that or stay nutral when you start it and spin when you rev it sorry i never had a scooter before just making sure its normal
Post by walleye1963 on Jun 13, 2015 15:33:08 GMT -5
The back tire should not spln it will burn your clutch up a stop sine.if your carb is that messed up I'd just wait until you get the new one.by the sound of it you will never get that carb to work right.
Post by scooter2828 on Jun 13, 2015 15:46:02 GMT -5
Would the tire spinning have to do with the carberator always reving like your hitting the throttle im trying to think if thats ever happened to any one else scooter
Post by walleye1963 on Jun 13, 2015 15:53:16 GMT -5
Yes.like I said I'd wait until you get new carb.then you will see the diffrents.if your on you scoot and all it wants to do is go then your clutch is engaged and all your doing is burning it up.with it engaging with the hi idle is not good.when you first start it is it at a real hi idle?
Post by scooter2828 on Jun 13, 2015 17:16:20 GMT -5
Yes it was really high it was around 7rpms i got it down but the throttle adjustment keeps turning and spinning on its own as you said the carb is messed up as the floater pen is bent when i get carb hope it makes a huge cgange if the back tire keeps spinning after we put the new carb on what should i do to fix the tire from spinning just adjust the throttle
Post by walleye1963 on Jun 13, 2015 17:36:45 GMT -5
OK the throttle cable you hook up to the carb.there's a screw with a spring to lower the idle turn it conter clook wise.that will lower the idle .if you turn it clook wise it will idle hi'er.
Post by walleye1963 on Jun 13, 2015 17:40:20 GMT -5
By the way what do you mean the throttle keeps turning by its self??? Do you mean the 2 nuts? If so tighten them down.
Post by walleye1963 on Jun 13, 2015 18:02:50 GMT -5
But if it were me I'd just wait until I got the new carb .don't mess with anything just put it on tighten every thing then hit the start .it should fire right up.then you can turn it.believe me iv only been on here a year.and the best thing you can do is read and read then read some more.after awhill you'll get it.this little mother's will make want you to pull your hair out but once you get it then you'll really want to pull your hair out.no just kidding or am I?
