Post by scooter2828 on Jun 13, 2015 18:32:52 GMT -5
Yeah its the throttle adjuster on carb that carb is messed up bad it starts up fine but its just back tire keeps moving just frustrating once you get to the poibt of starting it xou still cant drive it i know its something as small as that carb that messes everything lol
Post by walleye1963 on Jun 13, 2015 19:01:50 GMT -5
That's all it takes is something small to mess these things up.hey there China made enught said .but like I said just get on here and read .read about carbs and how to tune them.what ever you do .do it slow don't put on a lot of stuff at once do one thing one at at time.when you put on the carb turn it if it works good then you can move on.but do one thing at a time.if you want to ride .you will learn.
Post by scooter2828 on Jun 13, 2015 20:49:55 GMT -5
Yeah thanks im gettibg carb then working on the kickstarter the cover is broke so small small steps
Post by spaz12 on Jun 29, 2015 0:46:51 GMT -5
1. Why did you change this thread to a different one?
2. What motor is in this scooter? a. a 2 stroke motor b. a 4 stroke motor
3. With the Wheel on the GROUND, will the motor run? (I'm not concerned if it runs while on the stand)
Please answer these questions in order
Post by scooter2828 on Jun 29, 2015 13:49:18 GMT -5
Post by scooter2828 on Jun 29, 2015 13:52:37 GMT -5
Its a 4 stroke engine it is low sounding on wheels when i try to rev it no gas
Post by scooter2828 on Jun 29, 2015 20:59:01 GMT -5
Thr bell is moving with the clutch put a washer in bewtween see if that works
Post by spaz12 on Jun 30, 2015 0:43:23 GMT -5
It's a very specific washer IF it needs to be there.
is it easy to spin the back wheel with your hand ?
Post by walleye1963 on Jun 30, 2015 1:06:54 GMT -5
It might have the wrong size belt in it to.just putting it out there.
Post by scooter2828 on Jun 30, 2015 1:11:19 GMT -5
The guy said he changed the belt if i took it off whst would be the difference would the back tire stop spinning just so i know because on center stanf it starts up but not on wheels and dies when i press breaks for back tire
Post by scooter2828 on Jun 30, 2015 1:13:56 GMT -5
Backtire is easy to spin with hand
Post by spaz12 on Jun 30, 2015 1:24:42 GMT -5
Somewhere, I don't know what part, between the tire and the clutch bell...there's gears, bearings, torque driver, clutch, more bearing, bell.... something is locking that rear wheel to the motor. Until you post a video, I can only guess. And I'm done guessing
Post by scooter2828 on Jun 30, 2015 1:28:25 GMT -5
Post by frank50e on Jun 30, 2015 13:59:47 GMT -5
This is like watching ping pong.As bad as I HATE TO DO THIS YOUR VALVE CLATTER IS HIGH.Go to the archives watch and rewatch valve adjustment while waiting for carb which must be enroute from Siberia.
Post by scooter2828 on Jun 30, 2015 15:35:34 GMT -5
Whats the best guess why its licking up
