Post by renagade281 on Jul 16, 2015 20:54:18 GMT -5
Well the actual threads in the rocker arms are stripped also. Can I find me a link for 69mmm rocker arm w screws. I didn't order anything yet
Post by usmcdoc on Jul 16, 2015 20:56:26 GMT -5
I will find it right now..
Post by renagade281 on Jul 16, 2015 20:57:49 GMT -5
Thank u. I could find any grrrrr
Post by usmcdoc on Jul 16, 2015 20:58:04 GMT -5
Post by renagade281 on Jul 16, 2015 21:00:27 GMT -5
So the rocker arm assembly is the actual rocker arms
Post by usmcdoc on Jul 16, 2015 21:06:53 GMT -5
Post by renagade281 on Jul 16, 2015 21:14:22 GMT -5
I sure will thanks so much
Post by usmcdoc on Jul 16, 2015 21:26:25 GMT -5
You are much welcome Sir..that is what this site is about..learning..teaching..and helping others..
Post by Silar on Jul 17, 2015 7:05:45 GMT -5
Can't go wrong with Scooters To Go. They have good parts and are pretty fast at shipping!
Post by Availien on Jul 17, 2015 11:11:16 GMT -5
STG has helped me out a BUNCH. Love dealing with those guys. Good parts too.
Post by renagade281 on Jul 17, 2015 12:09:44 GMT -5
Realized I didn't have any oil in it either when I checked last night
Post by frank50e on Jul 17, 2015 21:03:40 GMT -5
We always call that "floating" the valves and the metric bolt tip is a good idea.In fact with a cut off tool or hacksaw and grinding wheel or file you can make your own.That is unless the rockers stripped.
Post by Availien on Jul 17, 2015 21:03:40 GMT -5
You should probably check your oil at LEAST every time you get gas. Small engine=small oil capacity. If there's a little bitty leak, it can be a huge problem in a few days.
Post by frank50e on Jul 17, 2015 21:08:13 GMT -5
Guess I should learn to read.If your really in a pinch for transpo you could try drilling and tapping the rocker arm.Never tried it don't know how hard the chinasteel is.
Post by renagade281 on Jul 18, 2015 9:55:47 GMT -5
We always call that "floating" the valves and the metric bolt tip is a good idea.In fact with a cut off tool or hacksaw and grinding wheel or file you can make your own.That is unless the rockers stripped. I was wondering that. If I could just get a bolt and file it down to the correct length so that when I tighten it there is just enough to fit the feeler gauge in it.. that it's when I get my new rocker arms
