Post by usmcdoc on Jul 18, 2015 10:18:24 GMT -5
We always call that "floating" the valves and the metric bolt tip is a good idea.In fact with a cut off tool or hacksaw and grinding wheel or file you can make your own.That is unless the rockers stripped. I was wondering that. If I could just get a bolt and file it down to the correct length so that when I tighten it there is just enough to fit the feeler gauge in it.. that it's when I get my new rocker arms I have seen it done by folks in a pinch until their new adjuster bolts or rocker assembly came in. Worked fine...they simply bought a bolt of the same thread and a nut to match..cut it off with a hacksaw or Dremel cutting wheel to the proper length..and bang! A temp fix.. Glenn
Post by Availien on Jul 18, 2015 14:20:17 GMT -5
We always call that "floating" the valves and the metric bolt tip is a good idea.In fact with a cut off tool or hacksaw and grinding wheel or file you can make your own.That is unless the rockers stripped. I was wondering that. If I could just get a bolt and file it down to the correct length so that when I tighten it there is just enough to fit the feeler gauge in it.. that it's when I get my new rocker arms You'll still need to install a lock nut on the top side. Not just a filed down bolt. It'll come loose.
Post by renagade281 on Jul 18, 2015 15:14:28 GMT -5
i was talking about a bolt that was perfectly long enough that when tightened would have the perfect gap
Post by usmcdoc on Jul 18, 2015 15:14:44 GMT -5
Availien..I said that in my post above..wake up Mr...lol.. Glenn
Post by kkzxxx on Jul 18, 2015 15:56:34 GMT -5
had pretty much the same noise on a 2 stroke 70cc, after the piston disintegrated and I swapped in my old 50cc the noise was gone.Must have been too high compression and detonation.
Post by Availien on Jul 18, 2015 17:29:19 GMT -5
Availien..I said that in my post above..wake up Mr...lol.. Glenn oops.
