Post by spaz12 on Sept 28, 2015 20:28:45 GMT -5
So right now you have the positive and negative terminals from the battery charger hooked up to where the battery hooks up? And still nothing?
Post by 2001eton on Sept 28, 2015 20:34:53 GMT -5
I dont see place where a wire was once at ... Nd yea u had the positive hooked up to everything positve and in that picture were the blue and black wires are connected thats where i had the negative.. Nd no spark
Post by 2001eton on Sept 28, 2015 20:34:58 GMT -5
Just dash lights and horn
Post by spaz12 on Sept 28, 2015 20:37:58 GMT -5
I dont see place where a wire was once at ... Nd yea u had the positive hooked up to everything positve and in that picture were the blue and black wires are connected thats where i had the negative.. Nd no spark Use the battery charger as a 'battery' and connect to those two cables. The black and red battery cables. Just think of the battery charger as a battery.
Post by 2001eton on Sept 28, 2015 20:38:06 GMT -5
Yea thats what i did
Post by spaz12 on Sept 28, 2015 20:39:43 GMT -5
Well, maybe it's possible that you blew out that damn expensive E-ton cdi? They are expensive too.
Post by 2001eton on Sept 28, 2015 20:41:31 GMT -5
I have to let my phone charge and ill post up a pic.. If they that expenisive then ill get a aftermarket one maybe?
Post by derbiman on Sept 28, 2015 20:41:57 GMT -5
Try putting the ground on the engine to see if it makes a difference. Attach the cable on the engine case somehow.
Post by 2001eton on Sept 28, 2015 20:43:28 GMT -5
Try putting the ground on the engine to see if it makes a difference. Attach the cable on the engine case somehow. Besides on the frame where it is?? Or dissconnect the blue from the black and put just the blue in the engine?
Post by derbiman on Sept 28, 2015 20:46:46 GMT -5
Connect the ground clamp directly to the engine to see if there is a ground problem. It should still operate the starter and everything else if the engine is properly grounded. If not,the engine is not grounded.
Post by 2001eton on Sept 28, 2015 20:48:27 GMT -5
I cant use the starter kick start only.. The whole ignition key stuff is gone
Post by 2001eton on Sept 28, 2015 20:54:56 GMT -5
I connected positve to positive negitave to the valve cover and i got power horn and the dash light comes on
Post by 2001eton on Sept 28, 2015 21:03:11 GMT -5
thats how the ignition is i guess And this is all the wires that was near the batt
Post by 2001eton on Sept 28, 2015 21:04:58 GMT -5
And a better view of the cdi
Post by katastroff on Sept 28, 2015 21:10:40 GMT -5
