Post by 190mech on Dec 27, 2015 19:24:28 GMT -5
Heck man!Dont give up soo easy!!Did you try starting fluid?(dont try this at home,kids..)If you have fuel,compression and spark,its gotta at least make a bang..leaky crank seals will make it run bad,but it'll run..So do we have a hot blue spark?Do we have a clean carb with a full float bowl of fresh fuel inside?Just trying other junk parts is only going to add to your frustration.. NO,only horizontal engine type for the CPI..
Post by jeffker69 on Dec 27, 2015 21:09:36 GMT -5
So i started smelling gasoline, i looked at the carb and it was leaking from the bottom of the bowl where u can drain the gas at. Thescrew was tight so could that be the problem? Im going to try the old carb again and see what happens. And yes i have good spark. Brand new plug. Could it be the cdi? Maybe ill just strap on my 150cc 4t to this frame and call it a day!
Post by 190mech on Dec 28, 2015 6:33:40 GMT -5
If its dripping,its from the overflow tube,float level is too high,will cause flooding/fouled spark plug..If its got good spark the CDI is likely OK..
Post by 190mech on Dec 28, 2015 12:52:25 GMT -5
A couple other things,a clogged muffler wont let an engine start,and next time you try to start it,hold the throttle wide open for several kicks,that clears a flooded engine...
Post by triesandluth on Dec 29, 2015 2:49:51 GMT -5
If its dripping,its from the overflow tube,float level is too high,will cause flooding/fouled spark plug..If its got good spark the CDI is likely OK.. I second this, float level issue, after ruling out the other problems. Having spark is different from GOOD spark. If it doesn't bite and you can just hold it while cranking it then it's possibly too weak. I had a cdi that would work and produce spark but it was weak. A blue "racing " cdi. I swapped in a stock cdi and it sparked like crazy. Just some anecdotes, that's about all I have lol. I guess you could make sure your pipe is clear by making sure air comes out while kicking it over? I suppose there's other ways. You could get creative and attach balloons. Have all your hard work kicking it over pay off work balloon animals if it still won't start... Does it blow fuel out of the plug hole if you kick it with the plug out? Just curious.
Post by 180°off on Dec 29, 2015 7:57:27 GMT -5
It was A clogged Pipe! GDI! I never had that problem with a 4t, so I never would have thought of checking the darn Thing. Thank you guys for all your help
Post by triesandluth on Dec 29, 2015 8:40:10 GMT -5
It was A clogged Pipe! GDI! I never had that problem with a 4t, so I never would have thought of checking the darn Thing. Thank you guys for all your help How did you clear it? curious...
Post by 180°off on Dec 30, 2015 12:05:23 GMT -5
I haven't cleared it out yet. That's my problem now. Does anybody know the best way of doing this? I read burning it to ammonia to all sorts if weird ways. Anybody know the best way besides buying a new pipe+
Post by 90GTVert on Dec 30, 2015 13:34:44 GMT -5
Post by 190mech on Dec 30, 2015 19:11:33 GMT -5
If its a later model muffler,there is a cat converter lodged within..The best would be to saw that sucker in half,gut it and sew it it back up(you didnt read this here!)..Wish I had a stock muffler around,but I gave them all away,,Can you post what your pipe looks like?Maybe one of us could help you out...
Post by triesandluth on Dec 30, 2015 22:14:14 GMT -5
What we really need to help him with is finding a performance pipe! Then we could meet up halfway and terrorize a little Podunk town with 2t madness!
Post by 180°off on Dec 31, 2015 19:12:52 GMT -5
Well, I read about clearing a clogged pipe. I got some lye and am trying that as we speak. If it does not work then into the burn barrel it goes. I will post a pic of it in a lil while. I agree with triesandluth about getting me a performance pipe. LOL! I may be able to get one in a couple weeks hopefully. see How exciting my newyears eve day is. Man about 5 years ago i would of had 2 bottles of rum waiting for me. Thank god its not 5 years ago.
Post by 190mech on Dec 31, 2015 20:25:44 GMT -5
Any pipes at the junkyard??We used to burn our pipes in a camp fire in the 70's while we were burning something else..I lived thru those years,some of my friends didnt!!Happy New Year!!
Post by triesandluth on Dec 31, 2015 20:42:48 GMT -5
Yeah, 2 years ago this would've been my third day drunk, I would probably be passed out by now lol. More than 2 years ago, probably worse! Until pipe time, maybe consider drilling some of the pipe out if it seems like it can handle some more flow. Well, if you have jets to accommodate for the flow...
Post by 180°off on Jan 3, 2016 18:02:56 GMT -5
Well I gpt the exhaust cleared out. Got it running, so now I just have to play with the carb a lil and put the plastics back on and should e good to go. how do I hook up the oil pump? I know its not hard just thought It would be faster with une of you guys tell me. Happy new year!
