Post by ryan_ott on May 15, 2016 19:32:01 GMT -5
I would not run that mount like that, you are putting a lot of stress on the mount tab in a direction it's not meant too. You are actually trusting the strength of that bushing not to fall out. I would make a spacer to span the width and connect to case. Drill and tap the top of case if you don't have any other options.
slowmotron
just a cat tryin to scoot
Post by slowmotron on May 15, 2016 19:59:09 GMT -5
Anyone know what parts i need to bore my taotao out with minimal troubleshooting and what sizes? And what cdi is best if all im trying to do is get more torque and speed without messing the engine up? Thanks sorry for posting off topic just excited bc i just got it yesterday
Post by renagade281 on May 15, 2016 20:26:38 GMT -5
Anyone know what parts i need to bore my taotao out with minimal troubleshooting and what sizes? And what cdi is best if all im trying to do is get more torque and speed without messing the engine up? Thanks sorry for posting off topic just excited bc i just got it yesterday Get a BBK and the stock cdi on a taotao is unrestricted I believe. I think the stock cdi is better than the so called "racing" ones. It's all about carb and cvt tuning. U can get some good performance gains just by doing those 2 things. Then if ur not happy, put a big bore kit in it.
Post by renagade281 on May 15, 2016 20:29:30 GMT -5
I would not run that mount like that, you are putting a lot of stress on the mount tab in a direction it's not meant too. You are actually trusting the strength of that bushing not to fall out. I would make a spacer to span the width and connect to case. Drill and tap the top of case if you don't have any other options. On your thread where u made a bracket for the bottom of the shock did u put a bushing on the bracket? If so how did u put it on the bracket. I have a bushing from a parts scooter but idk how I would get it on a bracket
Post by ryan_ott on May 15, 2016 21:03:03 GMT -5
I didn't put a bushing in it. It's spaced so there is about 1mm clearance on the thru bolt and it's got a clip through the nut so it won't back off. Just use whatever size washers you need to support on the sides of the case mounting point.
If mounted rigid it won't be able to pivot.
Post by renagade281 on May 15, 2016 21:33:21 GMT -5
I didn't put a bushing in it. It's spaced so there is about 1mm clearance on the thru bolt and it's got a clip through the nut so it won't back off. Just use whatever size washers you need to support on the sides of the case mounting point. If mounted rigid it won't be able to pivot. I put a bushing on it. Oh well. We will see
Post by renagade281 on May 15, 2016 23:24:44 GMT -5
Post by renagade281 on May 16, 2016 1:06:03 GMT -5
I'm gonna put spacers on it tomorrow so it can have some pivot. Too tired tonight
Post by ryan_ott on May 16, 2016 5:25:13 GMT -5
That will work!
Post by Clank on May 19, 2016 1:36:24 GMT -5
Can't you get a rim offset spacer or a narrower tire?
Post by frank50e on May 19, 2016 9:08:16 GMT -5
Be a stud and just use a srut like we used to in the 70's.
Post by frank50e on May 19, 2016 9:11:02 GMT -5
I still ride two Rigids and I am nearing 70 yrs old.
Post by renagade281 on May 19, 2016 11:27:28 GMT -5
Can't you get a rim offset spacer or a narrower tire? i could have but this was quicker and cheaper lol
